Tile Surround - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-04-2009, 11:52 AM   #1
Tile Surround
Does the cement board go over the flange of the tub before tiling or just above? Every stud doesn't sit flush against the tub. If the cement board doesn't have to go over the flange the tile transition from cement board to tub will be even.
MikeyP is offline   Reply With Quote
Old 01-04-2009, 12:03 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
You are posting your tiling questions in the plumbing section. Perhaps ask a moderator to move your threads to get more help.
Depending on the information that was asked on your other thread, after the studs are aligned horizontally and plumb vertically, you can notch out the bottom of the cement back to fit over the tub flange. You still need a minimal gap between the CBU and the tub deck.
Angus
My Albums
angus242 is offline   Reply With Quote
Old 01-04-2009, 11:37 PM   #3
Would you also need caulking after the tiles are in place?
wilsonfrench is offline   Reply With Quote
Old 01-04-2009, 11:55 PM   #4
angus242's Avatar
Yes you would
Angus
My Albums
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Tile Tub surround golfer2b Flooring 26 08-30-2008 12:25 PM
Fiberglass surround or tile shower 220-221 Remodeling 2 07-27-2008 08:42 AM
Plastic shower surround on top of tile ok? 1973vw Remodeling 4 04-09-2008 12:22 AM
Tile Surround on Tub leted_82 Building & Construction 2 09-12-2007 08:34 AM
