Old 04-16-2009, 05:34 PM   #1
Tile shower with out center drain?
I'm building a tile shower but want to put the drain on the far side instead of in the center. To use a center drain means to notch, cut, or drill through 3 floor joists. I'd rather just let it drain to the far side, like a tub. Is this reasonable/possible and, if so, what is the necessary/suggested slope?
jrdamien is offline   Reply With Quote
Old 04-16-2009, 07:06 PM   #2
You can put the drain where ever you want as long as you slope to it. I usually figure a 1/4 inch per foot slope. so 4 ft would equal 1 inch.
al's sewer is offline   Reply With Quote
Old 04-16-2009, 08:56 PM   #3
another option is a trough drain. this one is 1/2" by 2 feet hidden at the very edge of the tile and the wall .... sometimes people like them to be more visible,prominent, larger, a design feature of the shower.
interlodge is offline   Reply With Quote
Old 04-17-2009, 01:50 AM   #4
How do I go about making that kind of drain? What's it look like underneath?
Old 04-17-2009, 08:43 AM   #5
lot's of companies make them, prices vary extremely widely from the utilitarian to outrageous. kohler and others also have full bases (K-9996, just an example as drain is on wrong edge for you). Generally they look like an upside down hardwood floor attachment for a vacum cleaner... a thin trough angled in depth toward a center outlet, some can be configured with end outlet.
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-17-2008 12:11 AM
Tile under the shower? Lynn_Rich Flooring 2 09-26-2008 09:39 AM
Fleible drain hose for shower? devouru Plumbing 1 06-25-2008 11:06 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 09:59 AM
