Tile Going Out Of Basement. - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-11-2010, 12:38 AM   #1
Rewards Points: 107
tile going out of basement.
There was an old stand pipe in my basement. OLd house, i think it was used for the washer at one time. It was a 4" tile but the stand pipe was a 2" steel pipe and elbow. They both rotted out and I get water coming into the basement. I broke the floor up so I could get a good look into the tile. It is separate pieces, about one foot long each. I am guessing they did this to make a turn shortly after exiting the basement. Was this a common practice to make a turn in the old days? I originally thought there was an old dry well but now believe it is just a leach field. I plan on digging about about ten feet and crushing and filling the pipe. Any reason not to do that? TIA
thunderhead is offline   Reply With Quote
Old 08-11-2010, 08:35 AM   #2
Rewards Points: 1,418
That could be part of a French drain system. The tile is in pieces so it can collect ground water; nowadays they use longer lengths of pipe with perforations or slits.
You should find out whether additional runs of tiles go all the way around the perimeter of the basement, either just inside or just outside the foundation. Meanwhile the best thing to do with the short section of tile you exposed is to dig a sump pump pit near that location and near the basement foundation wall. A washing machine drain should never have been put into a French drain system.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Ceramic Tile over painted basement floor Wildie Tiling, ceramics, marble 7 05-03-2010 05:50 PM
Slate tile on concrete basement floor... tigerbalm2424 Building & Construction 7 06-13-2008 11:49 AM
Concrete basement slab + Radiant + Tile MageMinds Flooring 4 08-21-2007 01:52 PM
Adding toilet in basement with tile on the floor Kyle Plumbing 6 09-13-2006 09:59 PM
