Tightening Toilet To Floor? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2009, 07:46 AM   #1
Tightening toilet to floor?
I installed my first toilet last night, and am a little paranoid about the bolts. The floor was not level, so I ended up having to shim on side of the toilet by about 1/4". I bolted the toilet tight to the floor, trying to be careful not to go too tight while at the same time trying to get the toilet level, and didn't hear any cracks. It was pretty snug, but I wasn't having to crank the wrench hard to turn the bolt.
My question is, if the toilet didn't crack last night, what chance is there that the bolts may still be too tight and could crack later? I may just be paranoid, but I just wanted to see if I should consider loosening them back a little.
Thanks!
benhar is offline   Reply With Quote
Old 01-28-2009, 08:12 AM   #2
Registered User
Termite's Avatar
Your bolts only have to be tight enough to hold the toilet down and keep it from shifting or wobbling on the shims and compromising the wax ring seal. Just use lots of shims and get support under all areas of the toilet that don't contact the floor. The toilet is pretty darn tough and you can snug them down pretty good without breaking the toilet. Tight, not too tight!
Old 01-28-2009, 09:38 AM   #3
Rewards Points: 562
I HOPE you sat on it in normal fashion,,,and squissed the wax ring down to normal height??( I wiggle around a bit. If so it should remain tight,,if not it will be loose so sit on it and retighten. may not be by the book,,but its how I do it!!
4just1don is offline   Reply With Quote
Old 01-28-2009, 10:36 AM   #4
Oh yeah, I definitely used a good number of shims and sat on it and moved around a bit while sitting. It seems pretty secure. I was just wondering what the risk is of cracking after the fact.
Toilet rocks on tile floor Richo Plumbing 18 11-19-2012 12:04 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
