-   -   tightening mounting nut on sink strainer (http://www.diychatroom.com/f7/tightening-mounting-nut-sink-strainer-111524/)
amakarevic 07-21-2011 05:47 PM
1 Attachment(s)
i am having a hard time tightening the mounting nut on my sink strainer. tried useing a slip-nut wrench but it opens only 1-3" and the nut is slightly wider than that on the outside. also, wasn't able to find a bigger wrench. tried also to hold the basket at the bottom of the sink with channel locks, again to no avail because the nut gets too tight on the threads before it tightens the whole setup vertically.
am i doing something wrong and is there a different tool i should use?
thanks
picture attached.
TheEplumber 07-21-2011 07:40 PM
199 Attachment(s)
I don't like a lot of the specialty tools. I prefer a pair of needle nose pliers and large channel locks. Open the needle nose pliers and insert into the slots on the strainer. This will be your backup wrench. Then use the large channel locks to tighten the nut.
I've seen your wrench before but never bought one. Doesn't that notch on the left hook the nuts lip and then you tighten by resting the right side against the nut while twisting?
jschaben 07-21-2011 07:54 PM
1 Attachment(s)
thanks
picture attached.
I'm with ePlumber, not fond of one-trick-ponies either but in this case it's much cheaper than a large enough water pump plier which will likely get about as much use.
Check Home Depot or Ace for one of these, not sure what it's called. Print the picture if you need to and take it in.
