Tighten Toilet Tank Bolts - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-26-2010, 06:53 PM   #1
tighten Toilet Tank Bolts
How to safely tighten toilet tank bolts on Mansfield 3.5 gallon toilet Tank. Tips? Suggestins? Worried about cracking TanK.
bmenzie is offline   Reply With Quote
Old 09-26-2010, 06:55 PM   #2
Use hand tools NO electric drills etc. Once it snugs up, give it a 1/4 turn and you should be set.
wnabcptrNH is offline   Reply With Quote
Old 09-26-2010, 07:21 PM   #3
Snugs Up
By snugs up, you mean hand tighten?
Old 09-26-2010, 07:23 PM   #4
yeah by hand..tighten everything on a toilet by hand NEVER mechanically.
Its really a feel thing more than anything.
Old 09-26-2010, 07:46 PM   #5
Rewards Points: 1,548
Is there room for a nut between the tank and the bowl? As in a typical parts arrangement of bolt head, rubber washer, tank porcelain, metal washer, nut, bowl flange porcelain, metal washer nut. The middle nut is tightened against the tank bottom just before the tank is set upon the bowl although you may be able to install and tighten that nut with the tank already in place if that center nut was originally missing.
You can go an additional half turn with a wrench on the middle nut after hand tightening.
But the middle nut is not supposed to be the first thing that makes contact with the bowl when the tank is set down on the bowl. If it does then it is too thick.
Old 10-03-2010, 11:24 AM   #6
Wink
Thanks AllanJ
Thanks AllanJ.
I will try that. I also saw it on Kohler toilet in a Hotel room recently .
Thanks Again.
Toilet tank bolts? FrankL Plumbing 7 09-05-2010 09:32 AM
Leaky Toilet Tank Valve Tuckahoe Sparkplug Plumbing 4 07-10-2010 06:21 AM
Toilet Tank Movement dschucky Plumbing 2 05-04-2010 12:41 PM
Leaking tank bolts splinters Plumbing 4 12-25-2009 06:04 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
