Tighten Side To Side Action On Fawcett - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-06-2010, 03:56 PM   #1
Tighten Side to Side Action on Fawcett
I need to know how to tighten the fawcett spout when I swing it side to side on this style of fawcett. It is too loose and when I swing it to the left or right and turn on the water, it does not stay put. I am not sure where the adjustment is located. Maybee I have to tkae it apart? Anyone know? Brand is Latore
bubbasweet is offline   Reply With Quote
Old 07-06-2010, 05:45 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
The problem may be just worn o-rings at the top and bottom of the faucet body of the spout.
Turn the water off, disassemble the faucet and remove the barrel of the faucet.
Use a flathead screwdriver to remove the o-rings. Try NOT to cut or break them when you pry them out and off. You want to get a perfect match when you take them to the store.
See if that doesn't help.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-07-2010, 09:36 AM   #3
I notuce there is also a heavy weight on the hose for the spray part that pulls out. It seems this is contributing because when I move the tap from side to side the weight from this is pulling the tap spout back a bit. Maybee I need to raise the weight?
Timing for rebuilding of side entry: Help! navi_jen Remodeling 0 06-16-2010 10:02 AM
Should I use a vapor barrier on each side? Hossenfeffer Building & Construction 3 04-09-2010 10:12 PM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 08:19 AM
Side By side refrigerator Susie Q Appliances 6 08-31-2007 03:26 PM
