Tie Into Main Kitchen Stack - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-15-2008, 02:22 PM   #1
Question
Tie into main kitchen stack
Hi all,
I'm an avid DIY'er, but I'm new to the forum - hopefully someone can answer 2 questions for me.
I'm installing a sink in our kitchen island, and for the drainage I need to go through the floor and then tie into the main kitchen stack in the basement.
Question 1: Should I tie into the main stack as high as possible, or as low as possible? Or does it matter? There is nothing else tied into the stack in the basement, so this run would be below everything else.
Question 2: There will be 30'+ of DWV pipe (I'm doing a 'round-about' to avoid cutting into the joists, or taking up headroom) - will 1 1/2" ABS suffice, or should I go with 2"?
Thank you in advance!
Greg
gdub1973 is offline   Reply With Quote
Old 08-02-2008, 04:23 PM   #2
Send a message via AIM to Marlin
Kitchen drains need to be run in 2" pipe. Be sure to keep the line pitched 1/8" per foot. As for tying into the stack it shouldn't matter since you're not tying into a vent right?
Marlin is offline   Reply With Quote
Tags
abs , dwv , kitchen , plumbing , stack
vent stack for kitchen sink Knucklez Plumbing 4 04-02-2008 06:49 PM
Vent stack for kitchen sink stan 41943 Plumbing 19 03-16-2008 05:50 PM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 02:47 PM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 12:56 PM
