Tie Into Existing 4" Sewer Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-28-2013, 02:35 PM   #16
Rewards Points: 1,950
Originally Posted by TheEplumber View Post
Doesn't the IPC also use horizontal wet venting? I could see how this might blow traps. UPC allows vertical wet venting only for the most part- horizontal is allowed in some situations I hear, but not in my area.
If you think about it the wet vent actually makes some sense.
It only handles bathroom group fixtures.
The piping is oversized.
For example a vented lav is 1 DFU so your drain is 1.5 min.
Lets say I add a tub on that lav now we have 3 DFU I must bring the pipe up to 2 inch then we get the toilet it of course is 3 inch.
Flush the toilet and we need air.... It gets it off the lav vent.
Lets say lav gets blocked
Lav no longer drains so you know to snake it and reopen your vent.
I thought it was weird also. We vented all fixtures 20 years ago.. But after all this time it does work...
Old 03-28-2013, 08:49 PM   #17
Master Plumber
Javiles's Avatar
Rewards Points: 996
horizontal or vertical they are all vented at some point, we use the wet vent and the wet bend? we also use re leaf venting in situations like this. also depends on the specs of the pump.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-29-2013, 08:56 PM   #18
I just enforce it bro. I did not write it... Before Ohio adapted this code all fixtures had a vertical vent...
I just can't wait until we do the Philadelphia stack vent thing.... I heard that is the next one they plan to add..
tapping in to main sewer line for addition? yellowkid Plumbing 1 12-30-2012 12:21 PM
Sewer main line repair question dgeorge Plumbing 4 08-10-2011 07:21 AM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
Broken, busted, clogged storm sewer line... Upstate Steve Plumbing 1 04-07-2009 11:26 AM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 07:10 AM
