Tie In To Existing Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-23-2010, 03:58 PM   #1
tie in to existing plumbing
I want to entend my 4" sewer line into my addition and want to tie in at the existing cleanout. A new cleanout will be placed at the end of the line. Will I have to remove the cleanout fitting and place a coupling or is there a fitting I can use to tie in to the cleanout? The line is PVC an this will be done in a crawl space with adequate space.
Boudreaux is offline   Reply With Quote
Old 09-23-2010, 04:57 PM   #2
What is the distance of the new run? Is it a straight shot or is there going to be a bunch of offsets? I would replace the cleanout fitting with a new wye fitting to still maintain an active cleanout at this location if the existing line goes through the foundation wall right where you want to connect to. You want to make sure you have access to the underground pipe in case you need to snake it in the future.
The Engineer is offline   Reply With Quote
Old 09-23-2010, 06:00 PM   #3
Tie in
The distance is 9 feet. That is where the location of the toilet will be and the end of the line extension.
Old 09-23-2010, 06:01 PM   #4
Tie in
Sorry. It is a straight shot.
Old 09-23-2010, 07:23 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 352
Its not accepted practice to remove a CO plug and install a male adpt in order to extend the line. Typically you want to remove and relocate the cleanout or tie the new line in downstream of the existing CO then install another CO on the new branch line if its more then 5ft long. (based on local code)
Old 09-23-2010, 08:11 PM   #6
tie in
I will remove the cleanout and use a coupling to extend the line. Thank you for the info.
Tile over existing floor tile radient with electric heat brownieruf Off Topic 7 05-22-2010 07:49 PM
Dishwasher plumbing adaptors operagost Plumbing 2 05-11-2010 10:12 AM
Replacement Aluminium Window - Reusing existing sill flashing? GrantJohnson Building & Construction 4 02-10-2010 11:27 AM
Connecting new plumbing into existing plumbing Just do it guy Plumbing 2 02-18-2008 10:36 PM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 09:55 PM
