Thumping Sound Since Bathro Remodel - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2013, 03:23 PM   #1
Rewards Points: 28
Thumping sound since bathro remodel
Hello,
A month or so ago I finished an upstairs bath remodel. At one point I had to cut away subfloor around the toilet flange because subfloor was damaged from water. The subfloor patch didnt go back in as pretty as I would have liked but seemed to be fine. I then layed backer board and tiled.
After fixing the subfloor I also noticed a nail had pierced a vent pipe in the wall so I took it out and patched up the vent pipe.
These are the only plumbing related things I've touched.
Now everything is back together and when I flush the toilet I hear this thumping that sounds like water dripping onto the dry wall on the main floor. Sometimes just running the sink can produce the noise too. Any ideas?
dmack7 is offline   Reply With Quote
Old 02-24-2013, 04:57 PM   #2
MarginallyQualified
Rewards Points: 2,464
The subfloor patch didnt go back in as pretty as I would have liked...
Did the patch span two floor joists?
...when I flush the toilet I hear this thumping that
Any ideas?
Not really. What is under the toilet/stack?
Old 02-24-2013, 05:11 PM   #3
Rewards Points: 13,228
How did you "patch" it?
Old 02-24-2013, 05:14 PM   #4
Rewards Points: 28
Yes it spanned two joists and nothing stuck out as odd under the drain, just a standard trap configuration. I even tightened the bolts thinking it would tighten the connection of the toilet to the flange if the flange were flopping around causing the drain to hit the wall/ joist causing the noise.
Maybe if the flange were not secured properly? Or maybe the new subfloor not sitting right? I have no idea! At least there is no leak I guess but I wish I had a solution
Old 02-24-2013, 05:16 PM   #5
Rewards Points: 28
I patched it by cutting out the affected area and then cutting two new pieces to fit around the flange spanning 2 joists and some floor patch around the cut
Delayed sound Missouri Bound Home Theater 8 06-11-2012 01:42 PM
troubleshooting new sound card voltz PC Repairs & Upgrades 10 07-25-2010 12:16 PM
Anoying sound in house water pipes when sprinklers are ON gante Plumbing 1 06-07-2010 07:04 AM
Insulation with Sound Isolation Clips atmironov Building & Construction 12 05-06-2010 04:44 PM
Leaky Water Sound 24/7, need your advice. clue89 Plumbing 1 03-02-2007 08:36 AM
