Three Tubes On Drinking Water Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-02-2012, 01:38 PM   #1
Rewards Points: 16
Question
Three tubes on drinking water faucet
I am replacing my drinking water faucet and noticed that the new faucet has three tubes; one threaded tube that resembles the tube on my existing faucet and two small tubes labeled 1/4" inlet tube and 3/8" outlet tube. What are these other tubes for? The hole in my stainless steel sink is only large enough for the threaded tube. Do I need to connect the two small tubes to something or can I just cut them off at the base of the faucet so that I don't have to make the hole in the sink larger?
Cinci-Hal is offline   Reply With Quote
Old 01-02-2012, 01:42 PM   #2
Rewards Points: 13,250
And what does the directions say?
Old 01-02-2012, 01:43 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 986
You might have picked up the dispenser for the under sink hot water dispenser? They look the same except for the additional connection.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-02-2012, 02:04 PM   #4
Water Treatment
Rewards Points: 848
You have the RO faucet.. it has the three.
1 for the drinking water
2 for the discharge from the ro system.
1/4 to the faucet and 3/8 to the drain.
Akpsdvan is offline   Reply With Quote
Old 01-02-2012, 02:23 PM   #5
Rewards Points: 16
Thanks, Akpsdvan. What is an RO faucet? Can I still use it and can I cut off the two small tubes or do I need to connect them to something? The instructions that came with the faucet are not clear.
Old 01-02-2012, 02:30 PM   #6
A Reverse Osmosis water system with faucet...
Billy_Bob is offline   Reply With Quote
Old 01-02-2012, 02:35 PM   #7
Water Treatment
Rewards Points: 848
You could cut them, but that is a waste............ take it back and get one with out the extra tubes.
Doing it right the first time keeps one from having to do the job over.
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Outside water faucet replacement. As simple as it looks? ajtool Plumbing 3 07-27-2010 05:51 PM
Replaced Faucet. Now water smells of plumbers putty! emperor_black Plumbing 10 03-04-2010 09:19 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
