Threads Broken Off Copper DVW Pipe- Replacement? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-09-2013, 07:59 AM   #1
Rewards Points: 27
Threads broken off copper DVW pipe- replacement?
I am replacing an old vanity, and the P trap assembly had been connected to the DVW pipe in the wall via a fernco fitting (since I moved in). It is connecting the 1 1/2" OD p trap pipe to the 1 5/8" OD DVW pipe. Upon removing the fernco fitting I see why it was used- the pipe is broken off at the end, without any threads.
So- I could certainly continue to use a fernco fitting on this but it doesn't seem to be the most elegant solution. I am guessing that I could use a hacksaw to cut off an even section of the pipe, then sweat on a threaded connection, and thread in a slip joint of the appropriate size. I can't find a sweat threaded connection however- any leads on that? Or am I just approaching this wrong?
Any feedback is appreciated.
GerardW is offline   Reply With Quote
Old 09-09-2013, 08:06 AM   #2
Rewards Points: 27
Hmmm- came across this product when I searched for Copper DWV fittings:
http://www.pexsupply.com/Cello-WD84-...pter-8922000-p
Any ideas on if this will give me the "standard" DWV threads I need to put a slip nut on?
Old 09-09-2013, 08:12 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 818
Thats what you want
Old 09-09-2013, 08:16 AM   #4
Rewards Points: 14,020
http://www.bing.com/images/search?q=...electedIndex=6
For my money I'd replace all of that brass pipe and replace with PVC.
Way to many times I've seen copper and brass drain line corroded and leaking.
Javiles (09-09-2013)
Old 09-09-2013, 09:09 AM   #5
you need the adapter that joe had the link to. its called a trap adapter or
desanko.
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 09:49 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 10:55 AM
Damaged pipe threads Steve J. Plumbing 5 12-02-2007 11:33 PM
PVC pipe broken on Gas Furnace/AC unit Keyo77 HVAC 8 10-16-2007 03:08 AM
