#1 |
Threading black iron pipe?
Hello,
I can get black iron piep a lot cheaper at a metal distubuter but they will not thread it. Home Depot and Lowes will thread it but it is 2x the price. What options do I have to thread this pipe? It will be 1.5" and 1.25" piping. Thanks! |
#2 |
Rent a hand die and reamer, and buy a can of cutting oil. You can also rent a power pipe threader, and depending on how many threads you will be cutting, that may be the way to go. You still need the reamer and oil though. You will also need a vice to hold the pipe while threading.
If you have never made a mistake, you haven't done much. |
#3 |
Power Gen/RS Engineer
Being quite a novice at working with black iron, I am curious. When measuring and cutting the pipe, how much "shrink" do you assume due to the fittings threading onto the pipe?
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin |
#4 |
On one inch pipe, between 1/2" and 5/8". Depending on the condition of the die, it could be either. Best way to check is to run a fitting on the first thread and check it. Fittings can also run shallow or deep threads.
| Display Modes | |
| Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) | markmaclean80 | Plumbing | 6 | 08-22-2007 09:20 PM |
| Copper to Black Iron | BigJimmy | Plumbing | 1 | 07-23-2007 09:43 PM |
| iron pipe fittings | farrington135 | Plumbing | 1 | 07-13-2007 09:16 PM |
| Using a pipe threading machine (with 2" pipes) | amakarevic | Plumbing | 1 | 05-26-2007 02:23 PM |
| iron pipe fittings | Talman48 | Plumbing | 2 | 01-10-2007 06:11 AM |
