Threaded Unions Inside Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-11-2011, 06:05 PM   #1
Rewards Points: 1,062
Question
threaded unions inside wall
is it permitted to have threaded unions (e.g. regular or dielectric) inside a wall? someone told me it was not cause they are more prone to leaking. i plan to have some dielectric ones (copper->galvanized) inside my walls.
Old 10-11-2011, 08:21 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 850
Good question....I'm going to say no...unless there is access to the union.
That question came up awhile back regarding a P-trap in the wall...the guy wanted to use the threaded type....only allowed in there is an inspection door or other access....at least that is what was told....
Old 10-11-2011, 08:49 PM   #3
Mark Potter's Avatar
Rewards Points: 150
No any fitting that you can take off with channel locks or wrench can't put behind walls
Mark Potter is offline   Reply With Quote
Old 10-11-2011, 11:48 PM   #4
The answer is no. What is the reason you want to have unions in a wall, instead of straight pipe?
VIPlumber is offline   Reply With Quote
Old 10-11-2011, 11:57 PM   #5
because i want to have copper pipe inside the wall and galvanized outside for the looks. it is radiator pipe. i do not like copper pipe going straight into the radiator or even exposed whatsoever (like having a dielectric union outside connecting copper and galvanized). but inside the wall, obviously it is more convenient to have copper as it is easier to put together.
how about if i make a service panel entrance to where the unions are?
Old 10-12-2011, 12:32 AM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 354
Dialectic unions are not needed on hw heat systems. You can join copper to iron by using standard mip/fip adapters.
The Following User Says Thank You to TheEplumber For This Useful Post:
amakarevic (10-12-2011)
Old 10-12-2011, 12:43 AM   #7
oh man ... really ? that would be SWEET !! i thought dielectric unions are used to prevent corrosion on both ends. so you're saying i can do FIP->MIP (actually more like FCP->MIP) copper directly to galvanized steel ?
Old 10-12-2011, 11:28 AM   #8
Maryland
Install a copper drop ear fitting in the wall and then stub out with a galvanized nipple.
Pittsville is offline   Reply With Quote
The Following User Says Thank You to Pittsville For This Useful Post:
Old 10-12-2011, 12:08 PM   #9
but will it not work if i do galvanized male into copper female directly?
Old 10-12-2011, 03:05 PM   #10
Maryland
Yes, you can do that. I suggested the drop ear because it can be fastened to a framing member for additional support. It's just personal preference.
Old 10-12-2011, 03:11 PM   #11
thanks a bunch, man !! what would i do without you all?
Old 10-12-2011, 03:24 PM   #12
another question: do you think pipe dope can sustain high heat in close proximity? what i wanna do is twist the copper female onto the galvanized male and then sweat it to the copper pipe because i don't have room to rotate the whole assembly on the galvanized side? it would really s**k if i had to take it all apart.
Old 10-12-2011, 03:30 PM   #13
Rewards Points: 150
No it will just burn up and will eventually bond to the pipe and if you have pipe dope u have teflon which will burn too.
Old 10-13-2011, 03:53 PM   #14
Maryland
Might be a better idea to turn the copper with an elbow and a short length of pipe in the wall. This could give you more room to work on the outside when you're making the connection. Would surely save you some headaches if you ever need to disassemble that galvanized piping. Just a thought.
Mold inside a wall SheerLuckHolmes General DIY Discussions 7 03-30-2011 04:56 PM
Condensation inside wall on vapour barrier rovers1973 Building & Construction 1 05-14-2010 11:00 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
shower head pipe snap inside of wall? snosurfa7 Plumbing 3 06-06-2009 10:15 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
