Threaded Or Soldered Nipple - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2013, 10:33 AM   #16
Roofmaster
Rewards Points: 2,210
I think the drain 1/8 bend is Brass Joe. The corrosion is probably from the escutcheons. I think he could just unsweat those valves, remove the escutcheons, clean up the pipes and put new escutcheons and soldered 1/4 turn supply valves on there. No need to cut wall IMO. Well, that's what I would do. I would also check the drain stub out, and switch out the trap, of course.
Gerard, if I was you, I would replace all of your supplies that look like this. They have really had it. Probably original.
Threaded pipe corners mnp13 Building & Construction 5 03-11-2013 08:36 AM
radiator union elbow and valve nipple fitting amakarevic Plumbing 1 11-12-2011 02:30 PM
How tight can a brass nipple be installed? darsunt Plumbing 6 12-20-2008 09:09 PM
dead-end nipple before a gas appliance amakarevic Plumbing 14 11-02-2008 09:12 AM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 08:19 AM
