Threaded Elbows - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-16-2011, 03:49 PM   #1
Threaded Elbows
I have two PEX pipes (hot and cold) going horizontally into the wall. How would I connect them to a shower valve which has the two inlets on the sides (the PEX pipes are much lower than the valve)?
My idea is to use elbows to make the pipes go vertical, and then either FNPT adapter elbows or elbows and FNPT adapters to go into the valve. My main question is should I use threaded elbows or normal elbows and straight adapters? My concern is that the elbows have to point in a certain direction and what if the point where it's snug doesn't have the elbow pointing down?
And should I use straight couplings instead of the bottom elbows I was talking about and just bend the PEX pipe?
mtk369 is offline   Reply With Quote
Old 02-16-2011, 08:26 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 444
I'd put PEX x MIP into the valve. After that, I'd bend the pex without compromising the designed radius. Or use pex 90's
Old 02-16-2011, 09:04 PM   #3
What's MIP?
Old 02-16-2011, 09:15 PM   #4
Plumber
Rewards Points: 444
Originally Posted by mtk369 View Post
What's MIP?
Plumbers lingo-
MIP= male iron pipe thread
FIP= female iron pipe thread
So the adapter I referenced would be PEX x male iron pipe thread
Old 02-16-2011, 09:18 PM   #5
Originally Posted by TheEplumber View Post
Plumbers lingo-
So I should use a PEX to female thread elbow?
And having the elbow's PEX side not point in the right direction when tightened is not an issue?
Old 02-16-2011, 11:53 PM   #6
Plumber
Rewards Points: 444
What kind of threads are on the valve? Most are female. if yours is female then screw in pex x MIP adapters and run pex down to your supplies. I'm not understanding why you need threaded 90's. If you do use 90's, just tighten them until they line up where you want. With 1/2" pipe, you don't need to go super tight to get a good seal- hard to explain when to stop tightening- trial and error I guess
Old 02-17-2011, 09:26 AM   #7
This is the valve I'm considering using, and it has male threads:
http://www.danze.com/product_details...5&id=D113000BT
Flex for elbows? kindejj HVAC 9 06-25-2010 10:40 PM
Threaded shower valve connection NailedIt Plumbing 1 07-11-2009 11:06 PM
45 vs 90 degree elbows? Ultrarunner2017 Plumbing 5 03-18-2009 07:32 PM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 09:19 AM
solder or threaded brass valves?? fast380 Plumbing 4 01-13-2008 12:08 AM
