Thread Sealant(s) - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-29-2012, 07:18 PM   #1
jkk
Rewards Points: 233
Thread sealant(s)
What is the preferred method for sealing 1/2" pipe for water? Is tape sufficient?
jkk is offline   Reply With Quote
Old 11-29-2012, 07:30 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 770
I use tape and dope, one on top the other. Some use just tape.
I got to ask though, are you using a shark bite adapter?
Why not buy a compression angle stop?
Old 11-29-2012, 07:33 PM   #3
jkk
Rewards Points: 233
Don't know - are the compressions better? Cheaper?
Old 11-29-2012, 07:35 PM   #4
funfool's Avatar
Rewards Points: 534
The way I choose, and normally tape is fine in most cases.
I have found some troublesome drips where tape just did not fix it.
Paste is my preferred method, it never fails me.
Paste is not pretty, if you are going to see the connection, say a shower head in the shower, will use tape.
For the picture you showed, tape will work 99% of the time, if I was out of paste I would use tape.
I would prefer paste for that connection.
funfool is offline   Reply With Quote
Old 11-29-2012, 07:47 PM   #5
Rewards Points: 582
we use big blue tape...with rectorseal pipe dope.... ben sr
Old 11-29-2012, 07:50 PM   #6
Plumber
Rewards Points: 770
I love that stuff!
Old 11-29-2012, 07:52 PM   #7
Rewards Points: 582
I love that stuff!
yep great stuff...its been a long time since we had a leak using this stuff....ben sr
Old 11-29-2012, 07:57 PM   #8
jkk
Rewards Points: 233
Big blue?
Old 11-29-2012, 08:23 PM   #9
Plumber
Rewards Points: 770
Big blue?
When I hear big blue I think http://www.bluemonsterproducts.com/
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (11-29-2012)
Old 11-29-2012, 08:25 PM   #10
Rewards Points: 152
I always use at least 4 wraps of tape then a thin coating of pipe dope. Works great even on bigger pipe (2")
burnt03 is online now   Reply With Quote
Old 11-30-2012, 10:28 AM   #11
Household Handyman
Rewards Points: 1,408
I prefer rectum-tape also, but do agree that if the joint can be seen--use tape.
Old 11-30-2012, 08:32 PM   #12
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Cheaper for a compression angle stop than a FIP angle stop and an adapter.
I would even say that a compression joint is more reliable than a sharkbite any day.
Also : Normally only need tape for the joints unless the threads look really bogus/torn or something funky, then I use dope.
Normally use dope only on gas pipe though.
Journeyman Plumber
Need help:how to install false stair thread vluzhko Flooring 5 05-10-2010 07:13 PM
How to Subscribe to a Thread brokenknee How To Guides 1 01-25-2010 07:37 AM
