Think Anti-scald Tripped On My Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-11-2007, 05:37 PM   #1
think anti-scald tripped on my shower
Hi there, I bought an American Standard tub-shower valve combo, here is a link to the closest thing I can see from AS's site:
http://www.americanstandard-us.com/P...l=&prodID=1855
http://www.americanstandard-us.com/A...Sheet_1855.pdf
All hot water spigots in the house work exc. the tenant tells me this just stopped working - also that he heard a thumping noise. Now, cold water flows but not hot.
I suspect the "anti-scald" has kicked in as it's unlikely that anything could have lodged in there.
what I'm wondering is, how do I reset this? I would appreciate your help/input on this. I have limited access to the valve but can drill up through the void below.
Thanks,
Samuel
samf is offline   Reply With Quote
Old 04-11-2007, 09:45 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
You need to replace the cartridge inside the valve, remove the trim to acess the valve.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 02:58 PM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 12:01 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 10:33 AM
Installing a New shower facuet... BDPNA Plumbing 8 01-18-2007 08:23 AM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 06:17 PM
