Old 05-21-2009, 07:21 PM   #1
Default Things have gone horribly wrong
I was able to finally get the cartridge out of my bathroom faucet handle, and I got a replacement. The guy said that it was a hot water but now that I've installed it the handle is working backwards.
Problem two I took the cold water one out but it didn't look so bad so I decided not to replace it. Now however the cold water won't shut off. It doesn't seem to matter what way I turn the handle the water just keeps coming.
Fan in Exil is offline   Reply With Quote
Old 05-21-2009, 08:07 PM   #2
Okay, fixed the problem with the cold water faucet. There was an gasket that we placed incorrectly.
However now they are both backwards. The handles come forward to turn it off and go back to turn it on.
Old 05-21-2009, 10:06 PM   #3
There is no hot and cold cartridge, they are both the same. If the handle is turning the wrong direction pull the cartridge and turn it 180 degrees and reinstall.
hayewe farm is offline   Reply With Quote
Old 05-21-2009, 10:10 PM   #4
011000100110111101101111
DangerMouse's Avatar
what he said
DM
Magical, Musical, Mysterious FUN!
http://www.youtube.com/user/MickeySoume
Now Featuring: Mickey's Multi-Talented Mutts!
DangerMouse is online now   Reply With Quote
Old 05-21-2009, 10:22 PM   #5
Learning by Doing
Leah Frances's Avatar
FYI my old American Standard definitely has 'HOT' and 'COLD' valves. They are actually different. The Hot has larger round apertures, the cold has smaller triangularish ones. I have NO idea why.
Good luck with your sink troubleshooting. I try and take lots of pictures when I'm taking something apart so that I can put it back together correctly.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-21-2009, 10:33 PM   #6
Sounds to me like you have the hot stem on the cold side and the cold stem on the hot side. If you have lever handles the you will need a left handed valve on the cold side and a right handed valve on the hot side.
Jefftheplumber is offline   Reply With Quote
Old 05-28-2009, 09:21 PM   #7
KGP
Originally Posted by DangerMouse View Post
what he said
DM
x3 on that
KGP is offline   Reply With Quote
Old 05-29-2009, 11:46 AM   #8
This is the best picture that I could find. As you can see the cartridge itself is threaded. So pulling it a turning it 180 degrees doesn't actually accomplish anything. I also tried switching them with no luck.
Old 05-29-2009, 12:43 PM   #9
Fan, Are you saying that the cold water side lever use to turn off and on in the correct position, you took it out, didn't replace anything, reinstalled it using only the old parts and now the lever works in the opposite direction???
I'm not sure how that could happen. Try swapping them.
Old 05-29-2009, 01:30 PM   #10
That's exactly what I'm saying and I did try swapping them.
Old 05-29-2009, 11:25 PM   #11
Is the entire cartridge one piece that is screwed in place or is there an independently rotating threaded ring on the outside of the cartridge that is screwed down while the cartridge itself stays still?
Can the handles be removed from the shafts and repositioned to work as they did long ago?
Bait gone and the mouse trap has not snapped? Maybe ants got there first.
More On This Topic
Faucets should accentuate the overall appearance of your bathroom. You can choose from a large selection available at hardware stores, home centers, bath remodeling showrooms and plumbing wholesalers. You can also shop online. Whether you are replacing... Read More »
Hi I am Mark Williams and on behalf of Expert Village and the producer of this series you can visit our website at www.williamspictures.net. Just kind of go around the whole entire sink cause there are there is soap scum. Soap scum is caused when water... Read More »
Hey everybody, Don Golden for Expert Village and let's move on with the shower project. We've just taken off the valve and now I want to show you the real crucks of our problem is right here. This is called your water cartridge and this is right here, is... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we will be diagnosing our problem. We have a bathroom here that is set up with an older style faucets, now over the years this faucet has develop a leak which has gotten progressively worst... Read More »
Hi my name is Jon on behalf of Expert Village in this video clip we will be turning on the water and inspecting our work. If you recall from the beginning of our problem we had a bathtub faucet that leaked, our first point of inspection is just to take a... Read More »
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 04:44 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 10:13 AM
Whats right and wrong? eric s General Discussion 19 05-09-2007 10:03 PM
Painted Tub With Epoxy, And Things Went Wrong.. need Your advice... diyfan902 Plumbing 0 03-11-2007 03:19 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
