Is This Thing In The Picture My Water Shut-off Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-15-2013, 09:26 PM   #16
Rewards Points: 146
Sometimes there is a little water left over in the pipes. Has all the dripping stopped now? If not, then your probably right the supply valves are bad and need replacing. Can you post a pic? Thanks.
jmon is offline   Reply With Quote
Old 08-15-2013, 09:29 PM   #17
What kind of pic do you need? Can't finish installation until this weekend, after my dishwasher arrives (my hot water valve has a second opening for the dish washer line).
...I think I have a pic from my other thread. Lemme find it.
Here it is...
SurfAndSand is offline   Reply With Quote
Old 08-15-2013, 09:31 PM   #18
Rewards Points: 146
Yea that'll do. Anything to show the supply valves. thanks.
Old 08-15-2013, 09:34 PM   #19
Rewards Points: 146
They are the old gate valve style and should be replaced at some point. Do they work? Is water still dripping from faucet?
Old 08-15-2013, 09:35 PM   #20
I was only able to turn on the cold water at this point. No - it stopped dripping after a few seconds.
Old 08-15-2013, 09:44 PM   #21
Rewards Points: 146
Sounds like it's working alright. I see no sign of leakage from your supply valves. I don't think you need to turn the water off to your house to replace dishwasher or faucet, just use the supply shut off, that's what there for.
Old 08-15-2013, 09:47 PM   #22
Sounds like it's working alright. I see no sign of leakage from your supply valves. I don't think you need to turn the water off to your house to replace dishwasher or faucet, just use the supply shut off.
oh ok. Thanks. I was all concerned that it dripped some. I freaked out and shut off the valve.
Then I bought new valves and tried to turn off the water outside. When that failed, I got all desperate and tried to turn off the supply valves inside again, but more slowly. After it dripped a little, it would stop dripping, and then I just slowly opened it little by little, and it would drip some, and then stop.
Now that I've left it alone, it hasn't dripped. Shall I assume it's safe to use then? Initial dripping is normal?
Old 08-15-2013, 09:57 PM   #23
Rewards Points: 146
Those old supply valves need a lot of love. Sometimes they stick or seize up. Try to open and close them slowly a few times, this may help. Sometimes you can use a little lubricant as well. Yes, a little dripping then it stops is normal, not a continuous drip or stream. This would indicate your supply valve has failed or getting ready to fail.Thanks.Relax.
The Following User Says Thank You to jmon For This Useful Post:
SurfAndSand (08-15-2013)
Old 08-15-2013, 11:57 PM   #24
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
You have no other shut off, at all? I would definitely find out what is the process of getting the city to shut the water and get a proper inside shut off put in. Personally I'd get a plumber to do it, just because there is less chance of a leak or issue. Last thing you want is that valve leaking when the city is now gone.
You need a way to turn off all water for maintenance as well as emergency. If a pipe breaks or something you don't want to be waiting after the city to stop the water, and good luck if it happens past 4:30pm or if it's a weekend. The outside shut off valve is equivalent to the power meter, you can't really touch it.
Old 08-17-2013, 06:40 PM   #25
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Here's a pic of a plumber's shut off key. It looks close to what you have. Like E said, I would check with your water department first.
Thats for turning off a silcock or other small valve,not a water service.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 08-17-2013, 07:35 PM   #26
Keep scrolling.
hvac benny is offline   Reply With Quote
Old 08-17-2013, 07:42 PM   #27
plummen's Avatar
Oops didnt go down far enough!
Those are still what I consider pedestrian grade stop box wrenches,Ill see if i can dig mine out of the barn and post a picture.
Tankless hot water heater during winter when water shut off jdabs Plumbing 3 07-10-2012 01:50 AM
Hot Water Heater Problems Btabach Plumbing 7 05-21-2012 02:24 PM
No hot water past the valve at top of hot water heater-?- Daulton Plumbing 4 04-03-2011 03:47 PM
I still hear water running when I shut off the main water shut off valve jnut Plumbing 6 07-15-2009 08:46 AM
