Thickness Of Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-20-2012, 11:03 AM   #1
thickness of copper pipe
I want to move an outside tap for a hose, and have problems using the thick walled copper pipe--I am used to soldering thin walled pipe--can it be used (thin walled )for gardening and outdoor purposes--in Mass. I do not know if outside is covered in Plumbing code or not? Thank you oops and yes I want to hook it into a T that is in the house that has thick walled running into the T.
Kushie is offline   Reply With Quote
Old 03-20-2012, 03:04 PM   #2
Just a DIY guy
I don't know about pipe thickness, but you will want to put a valve inside the basement off that hose bib so you can drain it for the winter, or you will freeze and break the pipe. THe pipe should angle slightly down from the valve to the outside so it will drain.
Or put on one of these hose bibs (called a sillcock).
http://www.drillspot.com/products/39...proof_sillcock
M3 Pete is offline   Reply With Quote
Old 03-20-2012, 03:46 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 348
Type M, L or K are available. Assuming you're soldering a 1/2 or 3/4 line, the pipe wall thickness shouldn't be an issue. Sounds like your soldering skills need some work.
Old 03-21-2012, 09:25 AM   #4
Rewards Points: 150
Yeah those OD's should all be the same. In my area you can only use K for underground purposes. Just you regular M type and you are good to go.
psilva8 is offline   Reply With Quote
Old 03-21-2012, 10:45 AM   #5
If you can sweat thin wall then you can sweat thick wall.
Throw away the propane, get MAPP gas and you'll be fine.
Helper328 is offline   Reply With Quote
Tags
Heat safety during copper pipe soldering? darsunt Plumbing 9 08-14-2011 12:48 AM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
Copper Pipe Water Lines trophywalleye Plumbing 3 03-04-2011 09:44 PM
copper pipe vs pex I'm in trouble Plumbing 4 06-28-2010 12:42 AM
Replacing a section of copper pipe to a Gas Water Heater outlet Question F150dad77 Plumbing 4 10-07-2009 09:32 AM
