Thick Wax Toilet Rings - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-01-2009, 08:14 PM   #1
dIYHell
Rewards Points: 150
Thick wax toilet rings
I needed to replace the Wax toilet seal after about 3 months since i last replaced it? I replaced it by doubling the rings and it appears to be working but I noticed when I set the toilet it didn't take much pressure to get the rings to compress so I am wondering If I need even to use more that two seals. Is there any other way to get a good seal on a toilet flange when remodelling has resulted in higher floors?
rocketdoctor is offline   Reply With Quote
Old 05-01-2009, 08:25 PM   #2
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
There are stackable PVC closet flange extension kits available. While the best method is to actually lengthen the riser, sometimes that isnt practical. I've used these not only for customers, but also in my own home. They are usually 1/4" thick and you can stack them to get to the height you need. I like to put a bead of caulk between them just for good measure.
JDC is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet install - 2 questions BataviaJim Plumbing 11 05-11-2009 02:53 PM
two wax toilet rings? correllwl Plumbing 8 12-26-2008 07:51 PM
Need opinion - Need help - I believe my toilet was not installed properly rdlegacy Plumbing 9 05-06-2008 06:03 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
