From These Pics What Do You Think Is The Correct Way For The Backer Board - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-27-2009, 05:36 PM   #1
K.M.G's Avatar
Rewards Points: 119
From these Pics what do you think is the correct way for the backer board
Hi
Since I was getting behind on the Bathroom project we hired a Contractor
He told me running the Backer Board behind the tub is fine and the tiles will sit on the lip.
I looked at his work yesterday and see numbers written on the lip
That lip is the nailing edge to secure the tub to the studs I'm 100% sure and the numbers get hidden with tiles.
1,What it looks like now
2,How the tiles will sit on that lip
3,The Numbers I found
4,The Way I think the backer board should go
Cont....
K.M.G is offline   Reply With Quote
Old 11-27-2009, 05:47 PM   #2
That looks like drywall....not cement backer board ?
Drywall should not be used
Yeah - the tiles should come down & cover those numbers
Backerboard/seal should come down past the upper edge of the tub
But should not sit on the edge of the tub
Old 11-27-2009, 05:48 PM   #3
K.M.G's Avatar
Rewards Points: 119
5,The way I think the Backer board should sit on the lip and the tiles go
He comes back tomorrow and I want to have a talk but want to make 100% sure. I'm in the right before I say I would like you to place the backer board on the lip of the tub.(I'm no professional here)
Also I haven't figured out how he plans to secure the tub as he really doesn't want to go with the directions from the manufacture.They clearly state and show pictures of using 1" 1/2 Stanless steel screws to secure it into the studs.
3060_3260_tub_instructions_color_7-28-09.pdf
He says the tub will crack but they warranty the tub to be installed like that
I'm trying to figure out if I'm in the right here....
please do help
Old 11-27-2009, 06:03 PM   #4
K.M.G's Avatar
Rewards Points: 119
I thought that too...Was planning on buying Dens shield
We had already bought 5 sheets of Mtech2-Mold & water resistance Drywall for the room.
He then Told us we needed 3 more sheets,then I see him putting it on the wall.
I asked him if a inspector came in would he pass that to be used in the tub area for tiles..yes
So I just let it be as it was another $65 we spend and my Dens shield was $100
This is the old tub and the lip was covered with tiles
Old 11-27-2009, 06:04 PM   #5
Yep, definitely looks drywall. It should not go behind the tub flange. The tub should be fastened to the studs and the backerboard taken to the lip.
jerryh3 is offline   Reply With Quote
Old 11-27-2009, 06:42 PM   #6
K.M.G's Avatar
Rewards Points: 119
From what I get your saying it goes pas the mounting lip like this right...But it would be on a angle.maybe I don't understand
Or do you mean just above the tub like this 1/4-1/8's
I was under the impression it sits right on the tubs lip edge and is flat and flush like this(NO Gap)
Old 11-27-2009, 07:00 PM   #7
The backer board should go down past the edge of the tub like this pic you took
It should NOT be at an angle as properly installed it will be shimmed out to be level
It should sit just up from the edge - not ON it
That way if any water does get in there it will not wick up into the board
Possibly Denshield applied over the sheetrock meets code
Where are you located?
FLA or Canada?
Your location statement is a little confusing.....
Old 11-27-2009, 07:38 PM   #8
K.M.G's Avatar
Rewards Points: 119
This House is in Port Hope ont
Old 11-27-2009, 08:40 PM   #9
My plumber just installed my tub and he used some kind of cement under the tub to keep it in place and also take the bounce out of it.. Forgot the name of it. Also about the lip I just cut the back of the backerboard the thickness of the lip on the tub so it would sit flush on the wall. And leaving some space at the bottom..
sponge racing is offline   Reply With Quote
Old 11-27-2009, 09:04 PM   #10
Is there anything holding the tub in place right now?
Old 11-28-2009, 12:00 AM   #11
Registered User
Rewards Points: 526
Drywall behind the Denshield is OK, though not necessary as it will span 24". The fasteners should be rust-resistant coated or galvanized nails, 6" on center placement. The install as pictured will have a 1/4" problem if Denshield is run down over lip (as it should) within 1/4" of finish tub surface. It will angle inwards there. Someone correctly said to shim the wall before the drywall. The Denshield fasteners must penetrate the wood framing 3/4" to not void the warranty. No v.b. is required: http://www.ebuild.com/ImgRepos%5C102...g%5C102815.pdf
The tub should be fastened to the walls after setting in fresh mortar or drywall mud and leveling it. The tile should have equal width pieces on the sides when done and be within 1/8" of tub surface. Tile/tub, and tiles/tiles at inside corners should be caulked, not grouted.
I would search here: http://books.google.com/books?ei=8h0...spell&as_brr=3
Be safe, Gary
Old 11-28-2009, 09:31 AM   #12
K.M.G's Avatar
Rewards Points: 119
I think I will just cut my loss and buy the proper stuff Dens shield, so I know it's right and not half-azz
Also I will properly install the tub too
I haven't seen or heard from him in 2 days now so I'm taking the project over again.
Thanks for the info about the tub problem
Old 11-28-2009, 10:23 AM   #13
Home Remodeler
Rewards Points: 164
Something looks weird here. Are there installation instructions with the tub. The area where the letters and numbers are looks like what should be the nailing fin, but it than it looks like the top of the flange has another 1/2 inch flange. A picture of the flange without the sheetrock installed would help.
mikey48 is offline   Reply With Quote
Old 11-28-2009, 05:53 PM   #14
Registered User
Termite's Avatar
The part of the tub that has the letters should be covered with backerboard to about 1/4" from the actual top lip of the tub (the part you'll see below the numbers). The way to do it is to either make or buy furring strips (wood) and attach them to your studs right up to the top of the flashing fin. That way your backerboard overlaps the flashing fin of the tub and it doesn't have to be bent. The furring strips will go all the way to the ceiling.
You're making a good decision to use backerboard. BE SURE that you tape the seams with mesh tape and mud them with thinset.
Old 11-28-2009, 08:22 PM   #15
K.M.G's Avatar
Rewards Points: 119
I don't have many really good pictures of that
calking backer board to tub glassman General DIY Discussions 13 06-19-2008 08:41 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
tile backer board yudamann Flooring 1 06-29-2006 07:53 PM
