Thermocouple Volve - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-26-2010, 11:12 AM   #1
thermocouple volve
Hi, this spring shutted off the gas on my heating system and in the fall couldn't light the pilot. Replaced the TC (even it masured 25 Mv when hot) but no result. Replaced the valve, system working...Because of my 40 years of electronics exp took apart the valve and checked, no visible problem found..Just curious why it doesn't hold the first valve...Any ideas, thanks
silvermike is offline   Reply With Quote
Old 10-26-2010, 06:48 PM   #2
HVAC / Plumbing
Mv's are measured 2 ways. 1 is out of circuit ( just checking t.couple) the other is in circuit with an adapter. If the t.couple measured 25 mv out of circuit it would have measured 12.5 in circuit . With a good strong pilot the t.couple should measure 30 mv's out of circuit. Your pilot safety may have gone bad in the old valve using up your mv's
kenmac is offline   Reply With Quote
The Following User Says Thank You to kenmac For This Useful Post:
silvermike (10-28-2010)
Old 10-27-2010, 07:56 AM   #3
the old TC is working well with new valve system, something went rong with old valve...took apart...measured all connections...the coil...attached a new TC...heated on gas stove...not working
Old 10-27-2010, 01:32 PM   #4
HVAC / Plumbing
If the pilot won't hold . It's because the (magnet) pilot safety (the part the tc screws into) is bad
Old 10-28-2010, 07:59 AM   #5
tc valve
hi, what do you mean "bad"? the tc has to terminals - one is the body, another (central) is insulated from the body and shows infinity when the valve is removed from the body.
Old 10-28-2010, 10:19 AM   #6
HVAC / Plumbing
That would be the pilot safety within the valve
Old 10-28-2010, 11:06 AM   #7
tc valve
Is it possible to have a picture of this element and how can we test it, thanks
Old 10-28-2010, 01:47 PM   #8
HVAC / Plumbing
2nd page on the left side figure 3
http://www.robertshawtstats.com/spaw...sandPilots.pdf
silvermike (10-29-2010)
Old 10-29-2010, 06:49 AM   #9
Tc valve
Thank you very much
Old 10-29-2010, 07:04 AM   #10
HVAC / Plumbing
Your welcome
Old 10-29-2010, 12:46 PM   #11
Smile
Tc valve
I removed the valve and made a couple revolutions...put together ...attached the TC ...heated the end on gas stove flame many times...working perfect...
Old 11-06-2010, 11:00 AM   #12
tc valve
Any idea - can I keep it as a spare? Thanks.
Old 11-06-2010, 07:04 PM   #13
HVAC / Plumbing
valves aren't designed to be taken apart or field serviced.. You may not have put everything back together to make the safety work as it should.Personally, I wouldn't use it after it has had been taken apart
silvermike (11-06-2010)
Tags
tc valve
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Need help with thermocouple replacement on MC furnace YerDugliness HVAC 8 01-13-2012 07:24 PM
How long for the thermocouple to shut off the gas? dashworth HVAC 4 10-29-2010 08:41 PM
Bad Thermocouple in Carrier Furnace??? weagle HVAC 0 07-13-2010 10:33 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
