Thermal Expansion Valve Leaking Again - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-09-2017, 10:19 AM   #1
Rewards Points: 44
Thermal Expansion Valve leaking again
Hi,
In 2015 I had my Thermal Expansion Valve replaced as it was leaking cold water into the drain in my basement floor.
It used to have a 60psi rating, so they installed a 90psi rated one due to the high incoming pressure from the main larger valve (maybe the Pressure Reducing Valve?)
Is there a reason this Thermal Expansion Valve would fail just shy of 2 years?
I've heard from some neighbors that they just removed it completely instead of replacing. Good idea or no?
Thanks!
steve_e is offline   Reply With Quote
Old 01-09-2017, 01:49 PM   #2
Re: Thermal Expansion Valve leaking again
You are located in Canada. Terminology may be a little different. So you are talking about an hvac system or a closed loop system like a water heater.
I agree with you that the excessive high water pressure could be causing the premature failure.
There are several people from Canada that frequent this forum, please wait for one of them to respond. Thank you.
jmon is offline   Reply With Quote
Old 01-09-2017, 02:08 PM   #3
Rewards Points: 44
Oh, it's the thing that is right before the water enters the hot water tank. Normally there's a "water expansion tank" but this one just drains directly into the drain on the floor.
Weird, I cannot edit my original post.
Here's what it looks like
Scroll down to Photo 2: A Thermal Expansion Valve
Old 01-09-2017, 04:38 PM   #4
Rewards Points: 1,858
Install a thermal expansion tank sized for your water heater. Make sure incoming water pressure is below 80LBS
Old 01-09-2017, 09:03 PM   #5
Rewards Points: 268
Hard water can cause these to fail faster. Is your water softened before entering the valve?
BlackTiger is offline   Reply With Quote
Old 01-22-2017, 02:19 PM   #6
Rewards Points: 44
There's no thermal expansion tank, it's a pipe that goes to a drain in the floor.
The first valve thing that the incoming water is connected to (PRV?) says "adjustment range 25-75 psi"
The next thing is labelled as a Thermal Expansion Relief Valve, says 100 psi stamped on the end of it. This thing is what is leaking and causing cold water to go down a pipe into the floor drain. This is where I've seen thermal expansion tanks instead of a direct drain.
I've attached pictures to show the setup
Thermal Expansion Valve leaking again-file.jpg   Thermal Expansion Valve leaking again-file1.jpg   Thermal Expansion Valve leaking again-file2.jpg   Thermal Expansion Valve leaking again-file3.jpg   Thermal Expansion Valve leaking again-file-1-.jpg
Old 01-22-2017, 02:26 PM   #7
Rewards Points: 44
I don't believe so. I think our water is soft?
Old 01-22-2017, 02:30 PM   #8
An expansion tank would eliminate the valve entirely. Make sure you PR valve is only set to a max 80 LBS not sure what that is in your sizes.
Old 01-22-2017, 02:32 PM   #9
Rewards Points: 44
But why would it be leaking in the first place? Wouldn't it fill the expansion tank up right away?
Old 01-22-2017, 03:03 PM   #10
Rewards Points: 44
or does it only leak because the PR valuve is pumping through too high PSI for the tank? The Thermal Expansion Relief Valve is 100 psi, so shouldn't it be able to handle the higher pressure from the PR Valve?
What are the symptoms of a bad thermal expansion valve TXV? aluminumwelder HVAC 6 05-11-2015 05:58 PM
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Urgent help need - Kitchen sink valve leaking Andee77 Plumbing 1 02-11-2013 11:40 AM
leaking shower valve - fixed? wombosi Plumbing 0 06-22-2010 05:03 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
