Is There A Technique To Rodding? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-16-2009, 10:00 AM   #1
Rewards Points: 184
Is there a technique to rodding?
I tried a manual snake, and it gets stuck about a foot in, I think on a lip or something, when I have the plumbers out with their rodding machine, that goes through no problem, it seems that one, swings the cable around to it gets over the lip.
I also tried on you attach to a drill and that was worthless.
Is it worth it do spend $400 for one of the rodding machines?
Is there any technique to using one? I am just worried about forking over the $400 and the have the cable get stuck on the lip again.
abefroman is offline   Reply With Quote
Old 02-16-2009, 01:12 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 650
Ayuh,... Donno,.. I'd think it would be cheaper in the long run to just Fix the drain... Right...
Old 02-16-2009, 01:58 PM   #3
Rewards Points: 184
It is part of the interior drain tiles, not sure there is an easy way to fix that.
Old 02-16-2009, 02:35 PM   #4
You didn't say if it was a main line or those in the wall that you were trying to enter from. In either case, I would check out the Rental places. You can rent a motorized unit for lots less than buying. You won't have it taking up space once you are done either.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
How to remove a technique I did to my kithen walls ekolp Painting 5 12-31-2008 05:55 PM
Fireplace Mantle need help with color and technique Staticman2 Interior Decorating 4 12-11-2008 03:05 PM
edge sander technique drewhart Flooring 5 11-06-2008 11:10 PM
Texture technique Txmomof2 Painting 4 02-10-2008 09:14 PM
Painting Technique to look like "Grass"? GoldChain Painting 2 05-28-2007 02:09 PM
