Old 06-06-2011, 11:42 AM   #1
Seasoned DIYer
Is there such thing as a clear PEX tube?
It's a 1/2" pipe that looks translucent, much like 1/4" and 3/8" polyethylene(non-cross linked). Where I've seen it, it was fitted using Sharkbite fittings.
I couldn't find much info on polyethylene tubes. I found some info on larger ones, but they're opaque like black ABS pipes.
HVAC_NW is offline   Reply With Quote
Old 06-06-2011, 08:26 PM   #2
Household Handyman
Clear PEX tubing--not sure. Clear semi-ridgid tubing which has the characteristics of PEX, uses S.S. fittings and crimp rings--YES. Used at my previous employer site for sulfuric acid transfer. Used now at my current work site to transfer various chemicals. Did I mention expensive?
Old 06-07-2011, 02:54 PM   #3
If I'm not mistaken, all PEX comes in either blue or red color.
genie01 is offline   Reply With Quote
Old 06-07-2011, 03:47 PM   #4
fabrk8r
fabrk8r's Avatar
HEpex is available in translucent clear. It's made for radiant heating applications.
Potable water PEX comes in white, blue and red.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
For my refinished deck: BM Arborcoat Semi Transparent + Protective Clear Coat Domochu Painting 0 05-30-2011 11:47 AM
Replacing Spliced Knob and Tube fromscratch Electrical 6 05-24-2011 09:04 AM
Replacing a concrete tube lally Bob2468 Building & Construction 5 05-08-2007 09:27 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
How safe is knob and tube wiring? jackdp Electrical 8 10-29-2005 11:50 AM
