Is There A Standard Flush Valve That Will Fit A Mansfield 160? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-05-2012, 03:27 PM   #1
Is there a standard flush valve that will fit a Mansfield 160?
I have a Hydroright Dual Flush Converter that I'm trying to install into my Mansfield 160 toilet. To do this, I need to install a new flush valve, as the one that comes with the Mansfield 160 is centered over the hole in the tank, which is where the converter will sit.
The problem is, I cannot find a standard flush valve that will fit the Mansfield 160. I need one where the overflow tube is to the side (like most toilets, I believe). The ones that I've seen are all 3" in diameter, and the whole in the tank in my toilet is 2.5" (though somebody told me the Mansfield 160 needs one that's even smaller).
Can somebody recommend a way to find a standard flush valve that will fit this toilet? I've called 5 different plumbing supply stores, so I'm thinking I might just be out of luck, though I've read several things online suggesting that people "just replace the Mansfield flush valve with a standard valve".
Thank you.
pateras is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Kohler Persuade Dual Flush Valve Leaking Jackyl Plumbing 0 06-24-2012 11:48 AM
Flush Valve Seat sticking to Tank Ball Leah Frances Plumbing 2 05-23-2011 06:53 AM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
