Is There A Longer Bath Tub Drain Flange? Lined Cast Iron Tub. - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-18-2012, 09:56 AM   #1
Is there a longer bath tub drain flange? Lined cast iron tub.
After my 80 year old cast iron plumbing began to leak I started replacing the over flow and drain assembly with PVC on my first floor bathroom tub. After finally removing the cast iron plumbing I began dry fitting the new PVC parts and discovered that the drain flange and the drain shoe/waste elbow do not meet. I discovered that my cast iron tub was lined with a liner that is relativity thick. A standard (1 1/4") stopper/flange assembly does not work. After running to several hardware stores, plumbing supply stores and a making a few phone calls nobody seems to have an answer. Evidently a longer flange is not common, which I thought it would be since I know that I am not the only homeowner with a lined tub.
I have access to the bottom of the tub and the thickness of the liner/tub is about 3/4" to 7/8" thick. Does anyone have any suggestions? I appreciate your help. Thank you.
kokobeans is offline   Reply With Quote
Tags
cast iron , flange , liner , tub drain
Cast drain backup dcj710 Plumbing 6 09-20-2012 10:24 AM
Closet flange to old cast iron. rockys Plumbing 7 02-23-2012 03:57 PM
Leaking Connection Between PVC drain and Cast Iron Trap sleepyjen Plumbing 1 11-14-2011 10:43 AM
cast iron roof drain that is rotted steves smith Plumbing 2 09-22-2010 11:48 PM
floor drain / cast iron to pvc? n2learning Plumbing 3 08-01-2010 06:20 PM
