So I bit off more then I could chew in redoing a bathroom. The bulk of it is finished but its the details that are killing me. Basically, The tubspout that was sticking out of the drywall was about an inch too short after I redid everything. I bought one of those slip on tub spout kits from walmart, cut the pipe thinking it would work, and when I put the brass nut on and tightened the set screw, I must have tightened it too hard and crushed the pipe a little. I bought the stuff to sweat a new extension piece with the male adaptor so I could just screw a spout on, but I cant sweat it since it is so close to the cheap fiberflass tub surround. I had put aluminum foil layers over it to try and protect it, but it still started to melt. The tub spout will cover the melted piece, but not I'm at a loss. Anyone have some suggestions?[IMG]
[/IMG]
