Is There Anything I Should Do To A Cut Pipe Before Using A Push To Connect Connector? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-04-2013, 11:38 AM   #1
Rewards Points: 191
Is there anything I should do to a cut pipe before using a push to connect connector?
Do I just cut the pipe and attach the connector, or should I clean the outside with emery paper first (and/or do something else)?
Thanks all!
amateurplumber is offline   Reply With Quote
Old 04-04-2013, 06:57 PM   #2
Rewards Points: 13,300
Ok, what's the pipe made of? What type "connector"?
Old 04-05-2013, 07:51 AM   #3
DIY staff
Rewards Points: 7,174
Joe---I like your new signature line-------very helpful!
OP---what kind of pipe?
Old 04-05-2013, 07:56 AM   #4
Rewards Points: 582
no mike look at it better....not what kind of pipe .....its what the pipe....
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (04-05-2013)
Old 04-05-2013, 08:23 AM   #5
I trying to conserve on letters. I might need them later.
ben's plumbing (04-05-2013)
Old 04-05-2013, 08:59 AM   #6
Rewards Points: 191
Pipe is 3/4" copper. Connector is a John guest push to connect on one end and a falcon flex tube with fips connection on the other.
Old 04-05-2013, 09:39 AM   #7
Then your right just make sure there's no burrs, and a quick sanding with some emery paper.
Old 04-05-2013, 10:19 AM   #8
Roofmaster
Rewards Points: 2,172
If the pipe is perfectly clean, ream inside for full flow, very slightly chamfer outer edge so pipe slides into fitting. Do not sand outer side of pipe. Minute scratches in copper could be path for water. Seal is made between pipe and O-Ring. If you have to sand due to snots, use fine Emory, and only sand concentrically, not longitudinally.
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 01:31 PM
Push on connector - range element n0c7 Electrical 2 04-18-2012 03:56 PM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 06:17 PM
how to connect from sink to cut-off pipe jbcampo Plumbing 1 11-10-2010 05:17 PM
Replace PEX fitting with Shark Bite Push Connector? larrybr45 Plumbing 3 01-27-2008 03:01 PM
