Old 09-14-2007, 07:38 PM   #1
Is there any black PVC ?
Old drain pipes in my yard. Elbows are white and pipe is black. It is the old thinner walled stuff from years past. I don't see this stuff around any more. The elbows are marked PVC but there are no markings on the black stuff. Is it ABS for sure, or was there some black PVC? Pipe is more than 20 years old.
Melanie337 is offline   Reply With Quote
Old 09-14-2007, 08:39 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Got to be a mix of black ABS and white PVC. I'm not a pro plumber, but I've been an avid DIYer for more than 50 years. I've seen several colors of PVC pipe, but never black. That must be ABS. There is a "glue" for the two.
Mike
Mike Swearingen is offline   Reply With Quote
Old 09-15-2007, 01:03 AM   #3
Cabinet Installer
Dansbell's Avatar
It is possible that the fittings that were used were schedule 80 PVC while the pipe is only schedule 40. It is an odd combination due to the more expensive cost of the fittings. I have seen this done when the schedule 80 fitting is readily available an the schedule 40 is not. Schedule 80 is a stronger and more expensive. It is also dark grey in color. There is no reason that the combination wouldn't work in a situation that only required schedule 40. The outside pipe diameters are the same.
Daniel S. Bell
Belbuilt, LLC
Cabinet Installation Medford, Oregon
Dansbell is offline   Reply With Quote
Copper to Black Iron BigJimmy Plumbing 1 07-23-2007 09:43 PM
Black wood putty JOHNL Carpentry 2 04-27-2007 11:35 AM
Black Metal Roof??? Goat66 Roofing 2 01-31-2007 11:58 AM
Paint/seal over black mastic KBO123 Flooring 1 12-06-2005 03:11 PM
Williams wall heater produces black smoke skark_burmer HVAC 2 02-24-2005 08:15 PM
