Old 03-07-2009, 02:49 AM   #1
thanks/psi setting
Hi thanks for all the input on the pumbing projects .the pressure regulator is in and no leaks! what psi setting do you recommend (considering a backflow is inline)...60 -65 was what i was shooting for.I used to have 82 w spikes of 120.will be putting expansion tank in also.
any info is appreciated
hidden 1 is offline   Reply With Quote
Old 03-07-2009, 06:55 AM   #2
Remodeling Contractor
thanks/psi setting
50 -60 is about normal
Old 03-22-2009, 12:29 AM   #3
thanks/psi setting
thanks..
-if the pressure to home is set at 55psi would setting the expansion tank at 52 or 53 psi be a good setting?
Old 03-22-2009, 08:02 AM   #4
JDC
Plumbing Contractor
JDC's Avatar
thanks/psi setting
A setting of between 50-55psi on your expansion tank will be good if you have your prv set at 55psi. You want to be sure you dont have higher pressure in your expansion tank or its going to do you no good at all.
JDC is offline   Reply With Quote
Old 03-22-2009, 08:19 PM   #5
thanks/psi setting
thanks.yea i know the air is never to be above the line pressure ,which is why i dont like to match it -sometimes just a hair difference/above and it doesnt work. its at 52 now(air)..
Setting Pilings For Boat House donwells Building & Construction 3 06-22-2009 12:19 PM
Thermostat Setting handy man88 HVAC 5 01-18-2009 09:05 AM
Setting trusses for a Hip roof? TonyGG Building & Construction 13 09-13-2008 09:47 AM
Setting 3/4'' wedge anchors in concrete slab George Webb Building & Construction 4 02-27-2008 04:11 PM
How to deal with setting drywall compound? KUIPORNG Remodeling 11 01-11-2007 09:22 AM
