-   -   thanks/psi setting (http://www.diychatroom.com/f7/thanks-psi-setting-39810/)
hidden 1 03-07-2009 01:49 AM
thanks/psi setting
Hi thanks for all the input on the pumbing projects .the pressure regulator is in and no leaks! what psi setting do you recommend (considering a backflow is inline)...60 -65 was what i was shooting for.I used to have 82 w spikes of 120.will be putting expansion tank in also.
any info is appreciated
Bob Mariani 03-07-2009 05:55 AM
50 -60 is about normal
hidden 1 03-21-2009 11:29 PM
thanks..
-if the pressure to home is set at 55psi would setting the expansion tank at 52 or 53 psi be a good setting?
JDC 03-22-2009 07:02 AM
A setting of between 50-55psi on your expansion tank will be good if you have your prv set at 55psi. You want to be sure you dont have higher pressure in your expansion tank or its going to do you no good at all.
hidden 1 03-22-2009 07:19 PM
thanks.yea i know the air is never to be above the line pressure ,which is why i dont like to match it -sometimes just a hair difference/above and it doesnt work. its at 52 now(air)..
