Thanks Plumber 101 - Plumbing - DIY Home Improvement | DIYChatroom
Closed Thread
Old 05-23-2009, 07:36 PM   #1
Thanks Plumber 101
So are you saying not to mix the two pipe and tubing? Is there any problems with leaks with these biting connections?
Thanks, Stacey
staceythalmann is offline
Old 05-23-2009, 07:49 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
A shark bite coupling will not join the to together. But if you use a Male adapter shark bite for your service entrance and glue a female adapter to the CPVC you can make a connection.
A 3/4" CPVC OD will not fit into a 3/4" shark bite so using theaded adapters can make the connection. Mixing the pipe is not a big deal
No problems with leaks
Plumber101 is offline
Old 05-23-2009, 11:55 PM   #3
Registered User
Termite's Avatar
Please post your questions on the thread you started instead of starting a new one each time you post. Much easier that way and it keeps the site less cluttered. Thanks!
Termite is offline
Closed Thread
I Called a Plumber, Now I really need Help! kswoot Plumbing 8 10-14-2008 07:57 PM
HELP! I'm NOT a plumber. And I don't play one on T.V.! kswoot Plumbing 20 10-02-2008 01:14 PM
