Testing New Plumbing With Air Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-17-2010, 10:15 AM   #1
Testing new plumbing with air pressure
Has anyone used air pressure to test for leaks in new plumbing?
I plumbed a new double faucet shower, and don't have the final connections to the water supplies. But I wanted to test for leaks before I tiled without hooking up the water supply. So I soldered some threaded heads on the hot and cold pipes from underneath, put a threaded tire valve on the cold pipe and a air pressure guage on the hot pipe, and used the Delta dummy caps on the manifolds so air would flow.
I pressurized it at 90 lbs, and immediately found some leaks on the threaded pipes with soapy water sprayed on the fittings, and I fixed those. None of my soldered fittings leak.
My problem is I have now soaped and soaped and soaped and can't find any more leaks. But, I will lose pressure over 12 hrs and drop from 90 lbs to 60 lbs, then after 24 hrs it's down to 30 lbs. If it was a bike tire, it would be flat after 2 days.
My question is stupid, but...........I can't find a leak anywhere, and it's bleeding down. Do I still have a leak somewhere, or is this test over kill for what water pressure would be?
If I lose pressure over time like this, does that mean I will have a water leak too? Or is my test over kill for actual water pressure?
Signed, Baffled by No Bubbles
Niffumdutz is offline   Reply With Quote
Old 03-17-2010, 01:37 PM   #2
BIGRED
Rewards Points: 252
No unfortunately your test is not over kill. In fact here in the chicago area some counties and/or villages require a mandatory 100 P.S.I. for 24 hours test of the potable water supply for all new or altered installations. This does not mean just what you are working on. It means the whole system in your home. Something is leaking and it must be found and fixed. 30 P.S.I. over 24 hours is a pretty good leak. We've had as little as a 4# leak in 24 hours and the inspector won't sign off on it.
Look at your gauge threads and the shrader valve also. In fact put a heavy soap solution (almost a paste) on all the threaded connections and pump it up to 100 P.S.I. and slowly and quietly check everything. A lot of times you will actually hear a 1mm bubble pop before you ever see it. Good Luck.
Grampa Bud is offline   Reply With Quote
The Following User Says Thank You to Grampa Bud For This Useful Post:
Niffumdutz (03-17-2010)
Old 03-17-2010, 03:25 PM   #3
Ok, thanks for your response. I'd be happy to fix it, I just can't find it!
Old 03-17-2010, 06:09 PM   #4
why not test with water? put a boiler drain (hose bibb) on one of your lines and fill.
just a guy is offline   Reply With Quote
Old 03-17-2010, 06:44 PM   #5
Rewards Points: 1,214
You really should check it with water pressure its safer and more predicable.
Fill it up and make sure all valves are shut off when you start the test.
People have used air and it got away from them and blew up water don't blow up it just leaks all over.
COLDIRON is offline   Reply With Quote
Old 03-17-2010, 06:55 PM   #6
are your fixtures connected? or just rough in
The older I get the better I was
Old 03-17-2010, 07:57 PM   #7
They're just roughed in. I'm using the Delta dummy plates, which are a pretty sweet deal that I haven't seen before.
I put the pressure up to 100 lbs, and soaped again and found one tiny (!) little leak at the threads to the manifold. Went thru the fix it drill again, and put 100 lbs back on it.
We'll see what the pressure is in the morning. I know it easier finding leaks with actual water, and I would have done it that way, but it's easier doing all the rest of the plumbing later on.
Thanks for the input, guys.
Old 03-17-2010, 08:03 PM   #8
wondered if you might be losing air thru the fixture
Old 03-17-2010, 08:05 PM   #9
Well, that was my first thought too. So I soaped the living daylights out of it, and no bubbles there.
Old 03-17-2010, 08:09 PM   #10
Rewards Points: 370
What PSI is required for the pressure test? The working pressure for water pipe and fittings is 175 PSI. Water is the best chemical to use, cheapest and safest. Do not use air on plastic! PVC and CPVC will shatter when it breaks.
fireguy is offline   Reply With Quote
Old 03-17-2010, 08:17 PM   #11
standard plumbing piping and fittings are rated for 125#.
Old 03-17-2010, 10:11 PM   #12
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Usually our 'leaks' end up being the little needle in the valve stem we used to charge the lines.
Occasionally when testing with air, the leak will occur in a shower valve (air pushing past o-rings) and coming out of the shower head nipple. Capping showerhead will solve that issue.
Journeyman Plumber
Old 03-17-2010, 11:00 PM   #13
Thanks. That seems to be what's going on here. I don't have these kind of "leaks" when I hook up live plumbing.......maybe one or two.
Old 06-17-2011, 10:03 PM   #14
Hey niffumdutz, could you be more specific on that threaded tire valve connection to your plumbing, I have a raised slab to pour with pex tubing and need to check for leaks before the pour, I was thinking that maybe if I could find a way to connect a tire valve to the pex tubing, I could pressurize the tubes and check for leaks. but I don't know where or what exactly to ask for to convert and adapt to 3/4" pex.
livingdead is offline   Reply With Quote
Old 06-17-2011, 10:36 PM   #15
BIGRED
Rewards Points: 252
Livingdead : Are you puting down 3/4" pex in the slab for potable water or are you installing radiant heat?
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 07:04 AM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 10:50 PM
Pressure Testing the Filter system, What meter to get? zootjeff HVAC 1 07-12-2007 12:58 PM
Gas Line pressure testing standard(s) rolson6432 Plumbing 1 09-09-2006 03:33 PM
