#1 |
Testing for a gas leak
i recently installed new pipe and have completed the job and i am interested in pressure testing requirement.
I have about 70' fo 1 1/4 black pipe withe 3 connections and a PSI guage. I put 20 PSI of air on the line and used soap to inspect for leaks 12 hours later i have lost 5# of air pressure. What is premitted my soap testing shows no leaks. How long does the pipe have to hold and at what pressure. Does not the temperature of the pipe change the pressure of the air. |
#2 |
Journeyman Plumber
Spray the fittings down could be a pin leak on one of them, 15 lbs 15 min. Should not lose any pressure at all.
Fix it right the first time, so you won't have to fix it a 2nd time. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 | |
Union HVAC Tech.
Testing for a gas leakQuote:
| Display Modes | |
| Testing Formss | Deano710Sparkey | Electrical | 2 | 04-13-2007 02:33 AM |
| pipe leak & sheetrock damage | santogr | General Discussion | 2 | 03-04-2007 02:44 PM |
| Minute Gas leak | rjordan392 | Plumbing | 3 | 11-12-2006 11:59 AM |
| Bleeder Valve Leak | jwfran | Plumbing | 1 | 05-08-2006 09:12 PM |
| Hot water heater leak? | chrisintroy | Plumbing | 3 | 02-27-2006 10:13 AM |
