Test Waste - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-27-2010, 10:49 AM   #1
test waste
how do i test waste pipes after roughin them in.
urriah is offline   Reply With Quote
Old 10-27-2010, 10:53 AM   #2
waste testing how
Old 10-27-2010, 06:02 PM   #3
Rewards Points: 150
It depends on your system, normal way to do it is to cap or plug all the pipes in the system, you then go to the highest fixture, put a stand pipe on it approx. 10ft high, fill it up to the top and see if the water level drops, if it does, you have a leak, you can also use air but it is harder to find leaks.
braindead is offline   Reply With Quote
Testing Drain Waste Vent techinstructor Plumbing 1 10-21-2010 03:47 PM
Is this a waste pipe? quadari Plumbing 10 08-05-2010 10:58 PM
Kitchen Sink Waste Pipe... Help! AZLambdaK1 Plumbing 7 06-20-2010 01:20 PM
Exact waste factor on paper Justen Roofing/Siding 3 04-10-2010 04:54 PM
Ball valve with waste bbhmj Plumbing 2 06-03-2009 06:54 AM
