Test Three Phase Well Pump And Control Box - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-24-2011, 08:50 AM   #1
test three phase well pump and control box
My pump stoped working after a lightening storm. Franklin electric 1.5 HP run by a franklin electric subdrive 75 control box. this is a 4 wire system. My understanding is that the control box is a single phase to three phase converter. Main braker is good as well as the shut of switch. The power on light and fault light on the cover are both off, but when I test power output to the pump all three of the hot wires read 120 volt. How do I know if the controler, or pump is bad, or is it both?
mcjkmike is offline   Reply With Quote
Tags
well pump , well pump control box
Pump Control test Franklin wkosbob Electrical 96 03-22-2017 04:30 PM
Re: Pump Control test Franklin msenkpiel Electrical 1 08-04-2010 07:22 AM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
Well pump control box delema freeonthree Electrical 36 11-02-2008 09:55 AM
