Terrible Humming In Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-15-2010, 11:28 AM   #16
They said it is a water pressure issue which they didn't make any "changes" on their end.
purplepirate is offline   Reply With Quote
Old 07-15-2010, 11:35 AM   #17
Owner
LateralConcepts's Avatar
Originally Posted by purplepirate View Post
OMG... Water Authority just called back. Said it isn't their problem and for us to call a plumber.
Go buy a pressure gauge. Only a few bucks. Check that first. If it's over 80 PSI, I would install a PRV. Next step; if you're comfortable doing it, would be to shut the water off before the meter, pull the meter, and check for debris.
You said they were "ball" valves before and after the meter, or gate valves?
Is the pipe exposed after the meter or does it soon go behind finished walls?
Could be a broken clamp inside a wall somewhere as well.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 07-15-2010, 12:09 PM   #18
They are ball valves. A lot of pipe exposed after the meter. After the ball valve at the 11" pipe is appox. 2' copper pipe with a T. One end goes to the water heater other end shoots up into the ceiling.
Water Pipes Humming Smoke Plumbing 18 02-26-2013 07:24 PM
Humming in Pipes? But no water leaks we can see. bigbavarian Plumbing 2 06-25-2010 11:45 PM
Combining vent pipes in the attic. a4aj Plumbing 5 02-04-2010 12:20 PM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK Remodeling 7 11-04-2009 09:10 AM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 10:03 PM
