Terrible Humming In Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-15-2010, 09:16 AM   #1
Terrible humming in pipes
House is about 15-20 years old. Recently (past few weeks), there has been a loud humming sound in our pipes. Sound is constant, even when there isn't any water running. I've went around the house and started shutting off all valves to try and locate the source. Was thinking at first maybe the toilets or faucets were the culprit in some way. But when I turned the valves off (one at a time) at all the toilets and sinks, the humming still continued. In the home is a utility closet where our hot water heater and water meter are. I can feel the vibration on these pipes in the utility closet. The only other place I feel a vibration in the pipe is to a toilet in a bathroom where this utility closet is located. Although, when I turn off the valve to the fill tank, the humming still continues. In the utility closet, when the valve is shut off for the pipe coming out of the water heater, the humming still continues. When I shut off either valves on either side of the water meter, the humming STOPS. Have I isolated the area of problem? And if so, what is causing the humming and how do I fix it?
purplepirate is offline   Reply With Quote
Old 07-15-2010, 09:25 AM   #2
Owner
LateralConcepts's Avatar
I would check your water pressure. Do you have a Pressure Reducing Valve in the main line before or after the meter? It may have failed. The water pressure should not exceed 80psi
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 07-15-2010, 09:49 AM   #3
Did you also turn off the valves to your washing machine? Just one more place to check. What I have seen (rarely) is the rubber washers go bad, and allow air to be sucked into the water lines. Doesn't take much to cause humming since the washer will vibrate when air is crossing over it.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 07-15-2010, 09:49 AM   #4
There isn't a PRV before or after the water meter. Written visual view of the water line...3 1/2" from floor, ball valve -> 1 1/2" pipe -> elbow -> 6" pipe -> water meter -> 6" pipe -> elbow -> 11" pipe -> ball valve
Old 07-15-2010, 09:51 AM   #5
majakdragon...have turned off the valves to the washing machine also. Humming still continued. Also did not feel a humming in those pipes. The washing machine is located on the 2nd floor of the house. Humming and vibration of pipes seems to only be isolated on the first floor.
Old 07-15-2010, 09:53 AM   #6
Owner
I don't get it and have never heard of such a thing. 11" pipe?
EDIT - I re-read your post. I think I understand now you're speaking of "lengths" of pipe not pipe diameter haha. Guess I need more coffee
Lateral
(208) 818-8241
Old 07-15-2010, 09:57 AM   #7
11" copper pipe...was just a rough guesstimate, not an exact measurement
Old 07-15-2010, 09:57 AM   #8
Owner
So if you turn the valve off after the meter, is the meter spinning?
Lateral
(208) 818-8241
Old 07-15-2010, 09:58 AM   #9
Owner
Length?
Lateral
(208) 818-8241
Old 07-15-2010, 10:00 AM   #10
Meter was not currently spinning. Turned water on at sink in bathroom (meter naturally spun), turned valve off and meter stopped spinning.
Old 07-15-2010, 10:08 AM   #11
Owner
First thing I would do is check the water pressure then. I'm assuming you're on city water. There may have been a spike from the city. Any other changes in the last few weeks? Repairs to the city main? Excavation nearby? May need to pull the meter and check for debris, rust, etc. which may be the responsibility of the city.
Lateral
(208) 818-8241
Old 07-15-2010, 10:13 AM   #12
Yes, approx. 11" in 'length'
Old 07-15-2010, 10:19 AM   #13
Just call me Andrew
Rewards Points: 1,020
Do you have a pressure gauge? They sell them in HD or Lowe's - you can use it to check your static (no running water) pressure on your outside hose bib.
Andrew
secutanudu is offline   Reply With Quote
Old 07-15-2010, 10:24 AM   #14
I don't have a pressure gauge. Just called the Water Authority, explained the problem and all that was checked with the woman who answered the phone. She said she would find out what she could and get back to me.
Old 07-15-2010, 10:26 AM   #15
OMG... Water Authority just called back. Said it isn't their problem and for us to call a plumber.
Water Pipes Humming Smoke Plumbing 18 02-26-2013 06:24 PM
Humming in Pipes? But no water leaks we can see. bigbavarian Plumbing 2 06-25-2010 10:45 PM
Combining vent pipes in the attic. a4aj Plumbing 5 02-04-2010 11:20 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK Remodeling 7 11-04-2009 08:10 AM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 09:03 PM
