Old 01-31-2012, 08:56 PM   #1
Terminating a drain in the floor
I have removed a jacuzzi that was outside of the bathroom footprint. The drain is running horizontally through a 2x10 [COLOR=blue !important][COLOR=blue !important]joist[/COLOR][/COLOR] bay. The termination point sits approx. 2 inches from the top of the joist. I am unable to put a 90 on it and [COLOR=blue !important][COLOR=blue !important]cap[/COLOR][/COLOR] it. Can I install a fernco cap on horizontal run or should I reinstall a ptrap and then Fernco it. Or none of the above. There will be a finished floor above the drain. Thanks
tmiz19 is offline   Reply With Quote
Old 01-31-2012, 09:10 PM   #2
GC/Master Plumber/Mech
Can you post a pic?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 01-31-2012, 09:12 PM   #3
Super Moderator
A picture would be nice---but with very little info---if the pipe is PVC---cut it and glue on a cap-
Save the frencos for a time when a proper cap can not be used--
Type of pipe would help---
Old 01-31-2012, 10:31 PM   #4
The pipe is schedule 40 1 1/2 PVC. I will send a picture tomorrow. Thanks
Old 01-31-2012, 11:50 PM   #5
Mike has the right idea: a PVC glue cap. Prime glue and forget. I would suggest cutting out the p trap then capping the line, instead of leaving the trap and capping it's fixture side.
PlumbDumb is offline   Reply With Quote
The Following User Says Thank You to PlumbDumb For This Useful Post:
oh'mike (02-01-2012)
Floor drain for 2nd floor laundry TomU Plumbing 3 10-22-2011 09:35 PM
Storm water backup through floor drain bochnak Plumbing 6 08-03-2010 09:23 AM
floor drain / cast iron to pvc? n2learning Plumbing 3 08-01-2010 07:20 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
Basement Floor Drain amazinlittledevil Plumbing 8 01-04-2007 02:17 PM
