Tempoarly Taping A Gas Vavle ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-01-2013, 04:31 PM   #1
tempoarly taping a gas vavle ?
I have a gas valve in my basement that i think has a small leak ? Can i use Teflon tape temporarily to til i get a plumber ?
joanbone70Yahoo is offline   Reply With Quote
Old 03-01-2013, 04:35 PM   #2
Rewards Points: 13,712
Got a picture?
Where's it leaking?
Old 03-01-2013, 05:26 PM   #3
Rewards Points: 2,516
Pipe dope would be better or rectorseal 5
hammerlane is offline   Reply With Quote
Old 03-01-2013, 06:31 PM   #4
Roofmaster
Rewards Points: 2,210
This is insane. Just Fix it. Rector seal is good stuff. Forget teflon tape
Old 03-01-2013, 07:55 PM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 996
Leaks and gas dont go well together correct ASAP without experimenting or guessing.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
jagans (03-01-2013)
Old 03-02-2013, 06:29 AM   #6
Rewards Points: 1,216
Let me understand this better.
Do you mean just buying Teflon tape and just wrapping it around the outside of the valve to stop the leak until the Plumber arrives? Or do you mean take it apart and wrap it and replace it until the Plumber arrives?
#1 Call Plumber . #2 pipe dope.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 03-02-2013, 07:00 AM   #7
An old Tradesmen
Rewards Points: 7,332
Only certain teflon tape is approved to be used on gas lines. Regular teflon tape used for general plumbing is not approved.
Old 03-02-2013, 09:59 AM   #8
Roofmaster
1. Turn off gas main.
2. Call Licensed Plumber.
3. Re-Light Pilots.
If you ask a question like this, you are not capable of resolving the problem.
No Insult intended. Gas can be explosive.
Old 03-02-2013, 05:14 PM   #9
Rewards Points: 1,952
A little gas leak can only kill you!!! You guys are just to strict...
http://www.ksdk.com/images/640/360/2...3.jpg:thumbup:
Old 03-02-2013, 06:09 PM   #10
bbo
fixed
bbo is offline   Reply With Quote
Old 03-02-2013, 09:33 PM   #11
About a year ago I was removing a gas service to a house so it could be demolished. When I went to remove the meter, I found it wrapped in towels and plastic bags with an upside-down bucket over everything. Once I removed the bags, towels and bucket, I realized that there was a leak on the set. This must have been the resident's attempt at fixing the leak.
hvac benny is offline   Reply With Quote
Bathroom Taping dincanta Drywall & Plaster 1 03-02-2012 07:17 PM
Taping Drywall kupalino Drywall & Plaster 11 03-03-2010 07:20 AM
Taping suggestions misfitz Painting 1 07-02-2009 07:26 AM
Wavy taping seams - Help (drywall taping) newbpainter Drywall & Plaster 10 05-15-2009 09:36 AM
Taping an inside corner? helpless handyman Building & Construction 2 09-25-2008 02:34 PM
