Temp Waterline Above Ground - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-17-2012, 10:24 AM   #1
Question
Temp waterline above ground
Hello all,
My wife and I will be moving into the addition of an existing house while we tear down the original and build a new one where the existing main house is.
The water currently is coming from the main house, but since we will be tearing that down I need to shut that water off in the main house.
So my question is: Is there any solution to run a temp water line from the water meter to the temp house? I dont want to bury the line since we dont know the exact location or footprint of the new house. And since winter is coming I know it needs insulation. But since I am in Houston, Texas, we dont get many "hard" freezes.
Thank you for all the help.
kev98gsx is offline   Reply With Quote
Old 09-17-2012, 04:34 PM   #2
Rewards Points: 1,322
In your situation I'd bury the line about 4" deep and away from where any construction equipment could damage it and mark its location well for future reference.
Old 09-17-2012, 09:00 PM   #3
But I am trying to see if there is an option that doesn't require me to bury the pipe since I don't know the future structure's footprint.
Old 09-17-2012, 10:25 PM   #4
Rewards Points: 636
insulate pex inside a black corrugated drain pipe and if it gets real cold just let a sink drip slightly to keep a slight flow which will keep it from freezing
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 09-18-2012, 08:33 AM   #5
Rewards Points: 3,130
My wife and I lived in an RV on our property for a couple of years while building our house. We are in Eastern WV so freezing temperatures are a given. We are on a well so there is no meter. I put in a yard hydrant a few feet from the house, and ran PVC pipe on the ground over to the RV (about 50 feet. I then installed heat trace cable on the pipe and covered it with foam insulation. We had a few subzero mornings, but the pipe never froze.
What do you intend to do about sewer??
Old 09-18-2012, 09:03 AM   #6
the sewer is on its own, so no worries there.
but we dont get but a week total where freezing is an issue. but i just dont want a busted pipe.
Old 09-18-2012, 04:05 PM   #7
Well, if there's as little freezing as you say, just letting a faucet drip should be all you need to do. As noted above, moving water won't freeze.
Tags
insulate , pipe , temporary
Peerless oil furnace - keeps turning on when temp exceeds target temp eugenet1979 HVAC 0 12-22-2011 08:30 PM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 08:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 04:55 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
