Old 10-12-2009, 01:01 PM   #1
temp regulator / scalding protector..
My shower doesnt get hot enough to take a good hot bath. The water comes out of my sink hot enough to burn your hands.. but i can't get it hot enough in the shower to take a good bath. (think muscle relaxing).
If i turn up hot water heater "dial" to make it hotter, then yes, i can get the water in the shower to be hotter, but now its ridiculously hot burning fingers out of the sink.
I understand the function of the scald protection, but i thought scald protection monitored the MIX of the water, not the absolute temperature. If technically i can raise the temp of the shower by just turning up the hot water heater then the divertor really isn't a scald protector.
And yes, i took apart my divertor and set it to the MAX hot water adjustment. still not hot enough.
I just want my shower hotter without turning up the heat on my water heater. what i've actually done is took buckets of hot water from my sink and poured it in the tub to take a bath.
windowguy is offline   Reply With Quote
Old 10-12-2009, 02:10 PM   #2
Household Handyman
IF I understand your problem, you have a tub/shower diverter valve with built-in scald protection. And, you have adjusted the scald protection device to give you more hot water, but are not getting water as hot as you would like it. Question here--Would you by any chance have an additional thermal mixing valve in the piping to you tub/shower that may be controlling the water temp? I recently ran across this very issue and it drove us almost nuts (I'm close anyway), until we found this additional thermal control valve within an interior wall. OR- are you trying to exceed the manufacturers maximum setting for hot water at your tub/shower valve? Just a couple of thoughts there. Thanks and Good Luck, David
Old 10-12-2009, 04:16 PM   #3
the way you described my problem is 100% correct. i cannot tell you if i'm trying to exceed the manufacturers temp control because i havent put a thermometer to it to test how high i got it.
I'm just using my own skin as a gauge.
I don't know if there is another controller somewhere in the wall..i'm pretty sure there is not.
Back to trying to exceed the manufacturers max. It doesnt make any sense that i can exceed it if i turn the boiler temp gauge up higher, then effectively there is no "control" in the divertor because i can override it at the boiler. There is really just a "maximum mix" of hot water, not absolute temperature allowed to flow through.
So right now i think this is just a design issue with the divertor that i'm not happy with the maximum MIX between hot and cold, even though i have more than enough hot coming out of the sink.
Very inefficient that i have to make the entire house water supply hotter (and maintain wasting energy) just because i want the shower hotter.
Old 10-25-2009, 08:43 AM   #4
install thermostatic mixing valve and adjust the temperature from there..
jhao is offline   Reply With Quote
More On This Topic
Hi this is Jeff Wong with Expert Village and today we're going to learn the basics of maintaining your vehicle. In this segment we're going to be looking at how to check your tires. First we're going to learn how to check your tire pressure. So to check... Read More »
Operating a motorized pallet jack is a great way to move heavy loads that would otherwise be unsafe or impossible to move. But safe operation of a motorized pallet jack requires some knowledge and safety awareness. Here's how to make sure you're... Read More »
Speed Boat Warranties
Speed Boat Warranties by Expert Village
Standard on most motors and drives nowadays is the motors -- you get a V8 GM power plant, and you get an out-drive which is kind of like the transmission on a boat. That's what the props on and that's what spins when you give it gas the prop spins and... Read More »
Hello! My name is Christopher Fiffie and I have over 20 years of automotive mechanic. On behalf of Expert Village, we will be talking about how to change a flat tire. After opening the trunk, we will need to locate the jack, the lug nut wrench and the... Read More »
Hi, my name is Karl James, owner of Creolesoul Catering located in Round Rock, TX and on behalf of Expert Village I'm here to show you a crawfish boudin. Now for this heat portion we're taking a Serrano pepper, depends on how hot you want it add more or... Read More »
Making a ground for a surge protector Resilient Electrical 4 07-13-2009 08:11 PM
inside or outside temp fo P-T chart wetbar HVAC 5 06-21-2009 04:59 PM
Best High Temp Paint for wood stove?? Sellncars Painting 9 01-21-2009 07:21 PM
Is it a hazard to plug a surge protector into an ungrounded GFI outlet? CuriousWithQuestions Electrical 7 02-01-2008 10:04 PM
Kenmore Refrig. Temp. ? kourso Appliances 1 07-09-2007 12:37 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
