Temp Pressure Relief Valve Plumbing Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-18-2011, 12:43 PM   #1
Temp Pressure Relief Valve plumbing question
I am going from a side mount water heater to top mount, so the Temp/Pressure Relief Valve drain hole is in the wrong spot. A normal T/P Relief Drain pipe won't work. I have to do a couple of elbows and so forth to get it in the right spot.
Can all of this be done with CPVC fittings?
For instance will a CPVC threaded fitting be good enough to attach to the T/P relief valve itself?
I ask because there's a short piece of steel pipe going to my current valve and the other side of the steel pipe attaches to a flexible T/P drain pipe.
Thanks for any help you can provide.
poesprogeny is offline   Reply With Quote
Old 11-18-2011, 10:14 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
CPVC is fine for your T&P. You have to use the same size piping as what the T&P valve is threaded for. You need to make sure the piping grades away from the valve.
Journeyman Plumber
Old 11-18-2011, 10:17 PM   #3
Rewards Points: 582
agree with alan you can not reduce the size of your piping comming off the tpr valve 3/4 inch all the way to discharge
Old 11-19-2011, 06:38 PM   #4
Thanks for the help!
pressure relief valve leaks f9 flier Plumbing 21 06-14-2011 07:55 PM
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 06:32 AM
Boiler blowing pressure relief valve alecmcmahon HVAC 1 10-18-2010 06:52 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 08:48 PM
