-   -   Temp Pressure Relief Valve plumbing question (http://www.diychatroom.com/f7/temp-pressure-relief-valve-plumbing-question-123873/)
poesprogeny 11-18-2011 11:43 AM
I am going from a side mount water heater to top mount, so the Temp/Pressure Relief Valve drain hole is in the wrong spot. A normal T/P Relief Drain pipe won't work. I have to do a couple of elbows and so forth to get it in the right spot.
Can all of this be done with CPVC fittings?
For instance will a CPVC threaded fitting be good enough to attach to the T/P relief valve itself?
I ask because there's a short piece of steel pipe going to my current valve and the other side of the steel pipe attaches to a flexible T/P drain pipe.
Thanks for any help you can provide.
Alan 11-18-2011 09:14 PM
CPVC is fine for your T&P. You have to use the same size piping as what the T&P valve is threaded for. You need to make sure the piping grades away from the valve.
ben's plumbing 11-18-2011 09:17 PM
agree with alan you can not reduce the size of your piping comming off the tpr valve 3/4 inch all the way to discharge
poesprogeny 11-19-2011 05:38 PM
Thanks for the help!
