Teflon Tape Vs Pipe Dope - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2013, 01:31 PM   #1
teflon tape vs pipe dope
When connecting pipe fittings which is better? I had a carpenter tell me to use both. Does it matter if it's iron vs brass??
Edit- this is for a water line
mopowers is offline   Reply With Quote
Old 01-18-2013, 01:38 PM   #2
Rewards Points: 13,750
Going to get three differant ansewers for this one. All three will work.
Old 01-18-2013, 02:20 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,384
Ayuh,.... Personally,... I've never found a joint where pipe dope won't work,.... 'n work Well...
But,...
There's Many joints that pipe Tape, Absolutely won't work....
Old 01-18-2013, 02:27 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 684
Let me ask a question to you- what is the purpose of tape or dope?
Old 01-18-2013, 02:29 PM   #5
Is this a rhetorical question??
Old 01-18-2013, 02:37 PM   #6
Plumber
Rewards Points: 684
No The intent of dope or tape is to lubricate threads. If the threads are properly cut, the argument could be made that they'll seal themselves.
I feel safe using only dope. Others use both. Still others rely on tape.
So do whichever you please- someone will complain or have a better way.
I'm sure someone has commissioned a study on this subject
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (01-18-2013)
Old 01-18-2013, 02:51 PM   #7
Roofmaster
Rewards Points: 2,210
I use the white teflon dope. The fact is, that the fittings that you find in the big box stores are obviously foreign made and I have seen some that are actually oval. You can also see starts and stops in the thread form. Pipe Nipples have the same problem, often not round. This gives you a false impression of how tight they are in some cases. In theory Eplumb is absolutely correct, though. Lubrication NPT are tapered.
Old 01-18-2013, 03:44 PM   #8
Thanks guys. I'll double it up for good measure. Thanks!
Old 01-18-2013, 06:38 PM   #9
OK, stupid question.
What is pipe dope? I used teflon tape (2 layers) under my bathroom sink when I changed out the valves and ones leaking. A buddy gave my the blue teflon tape and suggested 3 layers used in gas piping, says a number of plumbers recommended it to him.
This is a picture before replacing the Valves.
VTOutDoorD is offline   Reply With Quote
Old 01-18-2013, 07:12 PM   #10
Bondo's Avatar
What is pipe dope?
Ayuh,.... This is 1 of My favorites,...
Old 01-18-2013, 07:58 PM   #11
Rewards Points: 4,796
There is a practical difference between using pipe dope and tape. Dope can get messy. So for example if you're doing a toilet supply connection of the type shown in the photo, there's a compression seal in there. If you were to get pipe dope in there, it might not seal correctly. Whereas tape will not cause that same problem. It's easy to wrap around the threads, and it's solid like actual tape so it's not going to grunge up something it shouldn't.
I can tell you I've read plumbing fixture instructions that explicitly said "don't use pipe dope". Not sure of the reason, but there you are.
It can never hurt to use teflon tape even where it's not needed, as far as I can tell.
jeffnc is offline   Reply With Quote
Old 01-18-2013, 08:04 PM   #12
Rewards Points: 582
no big deal on this one ....both are designed for thread sealant... some use pipe dope....some use tape....what is the big deal if it don't leak....and if it does leak with tape...try the pipe dope.....or the other way around...this can be put to rest....ben sr
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
Hardway (01-19-2013), TheEplumber (01-18-2013)
Old 01-18-2013, 08:08 PM   #13
DIY staff
Rewards Points: 7,174
Compression fitting do not need dope or tape--tape could get into the mating surfaces and cause a leak----
For the record---I'm a doper---sometimes with tape on top of it.
Old 01-18-2013, 08:11 PM   #14
Yeah, if tape got in there it could possibly cause a leak. I guess what I meant was it's less likely to get in there. If you gob on some pipe dope, you have no idea where it's squeezing to after you thread on the connections. But with tape, you can easily see how it's wrapped, and it's basically impossible for it to move up when you start threading down.
The Following User Says Thank You to jeffnc For This Useful Post:
Old 01-18-2013, 08:20 PM   #15
DIY staff
I like Bens answer----use what works for you--if that doesn't work--try the other one--no leaks--no problem
ben's plumbing (01-18-2013)
how to apply Teflon tape on thread? young707 Plumbing 10 08-23-2012 03:36 PM
Teflon Tape or Pipe Dope Jupe Blue Plumbing 3 05-21-2011 09:17 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
Pipe dope and teflon tape: if it's holding now, can I trust it? nilloc Plumbing 12 04-30-2011 01:28 PM
Pipe need to be dry when wrapping teflon tape? thisisbrianly Plumbing 5 09-27-2009 09:29 PM
