Teflon Tape Or Teflon Pipe Joint Compound? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-02-2007, 09:39 PM   #1
zel
Rewards Points: 150
Send a message via AIM to zel
Teflon tape or teflon pipe joint compound?
I am installing the faucets in my bathroom and was using this Teflon pipe joint compound. It seems to work pretty good, I can always remember not knowing if I had enough teflon tape on the threads, or sometimes I had too much and it wouldnt tighten enough, etc. This paste kinda takes the guess work out of it. Any reason why I shouldnt be using it on all these connections?
zel is offline   Reply With Quote
Old 04-02-2007, 09:54 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Age-old question, tape or compound?
Use the one that you like best that works for you...6 of one, half dozen of another, IMHO.
I use both (but usually tape). If you use tape, just make sure that you wrap it clockwise only as the threaded end faces you so that screwing on the fitting won't undo the tape.
Mike
Mike Swearingen is offline   Reply With Quote
Teflon tape or pipe dope chickenboo Plumbing 50 06-29-2011 08:16 AM
Teflon tape adequate for spout diverter? darsunt Plumbing 1 06-05-2007 01:50 AM
What brand of Joint Compound? mwehnes Building & Construction 6 03-26-2007 07:11 PM
tape and float - tape is coming off! samf Remodeling 3 09-29-2006 08:09 AM
PVC drain pipe leaking at joint, 2 part epoxy last? harleysilo Plumbing 3 09-26-2006 12:29 PM
